What should I do next?
Im ready to my next mod and not sure what to do next, Im building my truck to pull and to run down the qtr once in a while. Im thinking of going with the adrenaline hpop and retune next. What do you all think I should do next? Should I go with something else first? My goal in the end is to do the, traction bars, turbo, transmission, and injectors. Id like 238cc hybrids or stage 2 injectors. Nothing to crazy, I still want it to be reliable truck.
i'm a fan of stealth hpop's but that's just me
Did you notice any differance when you put just the hpop on? Have you ever ran it down the track, if so what times did you get? Also did you notice much of a differance when you put a 6.0 intercooler on?
one of the guys on here posted dyno runs from an e99, with the 15* hpop and then the adrenaline, and I'm guessing the stealth hpop is just as good, he showed 50hp increase with stock injectors from 293hp to 343hp iirc. what the power would be compared to a 17* I don't know, but I'm sure you'd see some.
I will have to see if I can find that.
regulated return would also be in the running......
What's best place to buy or build a regulated return? I've heard of guys leaking and bursting.
probably guys not using diesel rated lines? It will eat through generic rubber line, or soften it and then burst or push it out of the clamp.
Any of you all ran the pro comp ladder bars? I don't want to spend a million dollars for a set and these look like some of the others
Sinister diesel for the regulated return
