How much boost should I make? Boost leak? - Ford Powerstroke Diesel Forum
Old 01-02-2011, 09:15 PM
I have an early 99 with a ts6 pos chip, diy intake, and a dynomax race muffler. No matter if I have the chip on 50,75,100,140 I can't seam to get more then maybe 22lbs of boost and when cruising around town or on the freeway I only see around 3-5psi... I installed my glowshift boost gauge last weekend with a t fitting on the map line. I also did an overboost deal from dfuser. I installed the dfuser between the map and my boost t fitting on the map line. Is this correct?
If it is most likely that I have a boost leak where/how should I start looking?
Thanks guys
Old 01-02-2011, 10:37 PM
That's about where the waste-gate starts opening up. Try unplugging the red line temporary to see if you get more boost.
Old 01-02-2011, 11:11 PM
forgot to add the red line was disconnected already. Is it not kosher to drive like this?
Old 01-03-2011, 09:09 PM
Bump. What should my cruising boost be? I doubt I get more then 5 psi on the freeway unless I speed up to pass or hit a hill.
Old 01-03-2011, 09:34 PM
If you do have a boost leak its a small one. I can hit 30 psi on the 100hp setting, cruising on flat ground at 70 is usually between 1-4 psi. I would try just tightening all the clamps and see if that helps.
Old 01-03-2011, 11:04 PM
Well if that's what your getting then maybe I don't have a boost leak and the lower max boost could just be that I have an early 99..? I don't know if the early 99 made less boost or not, I would guess yes with the smaller turbo housing.
Old 01-04-2011, 05:44 AM
I was thinking that might be it because my buddies e99 only makes 23 but he doesnt have a boost fooler
Old 01-04-2011, 09:43 AM
I got on it last night and I only saw 20psi max no matter what setting I was on... Guess I better check those clamps.
Old 01-04-2011, 09:47 AM
theres a lot of guys, including me, that didnt get an accurate reading by tying into the MAP line. I did that to start with and only saw 8-10 lbs. so I drilled and tapped it into my y-pipe and am seeing around 35.
Old 01-04-2011, 09:56 AM
Pointless Poster
need to drill and tap your y pipe for an accurate reading. also many members are sceptical of glowshift gauges.
