Another Chip Question - Ford Powerstroke Diesel Forum
Old 12-29-2010, 08:15 PM
Hey Fellas,
New to the site and to the PSD world. I just bout a 01 F250 7.3 4X4 Crew with 85K. I want to chip it or program it to get a little better MPG but I'm not expecting a hybrid. My question is 2 part. What is the easiest to install programer, chip etc.. And do I really need to add exhaust, valve body, intake, and other things before I add a programer or chip? I'll def add exhaust but I'm not a racer. I don't tow anything big just a ATV once in a while. All hwy driving, and I live in Florida. Thanks guys! Sorry if this is a everyday question. I promise I've used the search button before asking!
Dan
Old 12-29-2010, 08:22 PM
all CHips are the same to install.. you will have to physically pull out the PCM to install it... the only thing you need to install with a chip is some gauges... but a valve body and a larger trans cooler is recommended...
i recommend this: Tony Wildman Chip
-Raul
Old 12-29-2010, 08:46 PM
Raul is a very smart man..
Honestly you need nothing, id suggest atleast cutting out the muffler on your stock system..your good up to 400HP then, a 6637 air filter mod is an easy addition to flow, and a valve body will help the tranny.
Gauges are about the only well needed thing..
