is this leveling kit Junk? - Ford Powerstroke Diesel Forum
Old 12-10-2010, 05:42 PM
Send a message via AIM to 350dieselsmk
Ford Super Duty 2 1/2" Leveling Lift Kit With Hardware - eBay (item 320628056611 end time Dec-17-10 18:08:52 PST)
Old 12-10-2010, 05:46 PM
not sure as Ive always just went and had leveling and lift kits made for all my leaf spring trucks. but heres a bump
Old 12-10-2010, 10:45 PM
I have heard some guys say they have used it and liked it. I have not used it and will not get a chance to because I got my truck with 4" springs that I will be trading for 2.5".
Fwiw the "mini spring" design looks to me to be just a block that is wider to prevent axle wrap and pass safety inspection.
Old 12-13-2010, 02:59 PM
Feedback Score: 5 reviews
I would get a mini spring pack from a spring manufactor thats made from spring steel not plate steel. You will also need a adj track bar to recenter your axle after the lift. We have quality kits..
Cary
Old 12-13-2010, 07:22 PM
i got my front add a leaf/leveling spring installed for $100
Old 12-14-2010, 05:32 AM
im looking for a levelin kit who did yours?
Old 12-14-2010, 09:49 AM
I'm with Cary on this one. Get a spring steel set, not plate. Yes, they cost a bit more.
These mini-packs are a great way to level the truck (similar to a block, but actually bolted to the existing leaves so they're in essence just a taller, multi-leaf spring pack but without the added spring rate).
I have installed one of these in a friend's 02 F350. Easy install with desired results.
Powerstroke Junkie
I would get the set up that Cary sells. I will be doing the same thing once I get some other things paid for. There is a right way and a wrong way to level a SD. Most do it the cheap, and wrong way.
Old 12-14-2010, 10:03 AM
2000 Ford F-350 Super Duty Pickup Base/Standard Revtek Suspension Parts: Suspension Components
My truck has the 4" revtek springs up front and I wanted it lower so I ordered the 2.5" springs and I guess it was in the nick of time... Don't know if it was a closeout or what.
Old 12-14-2010, 11:10 AM
This isn't the right way to do it? All these years......
Well then, how about this?
