need info!!! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-03-2010, 05:36 PM Thread Starter
Red face need info!!!
I had just recently bought a 00 f250 7.3L PSD 6spd 2WD, and its my first diesel. I'm planning on spending a lot by upgrading this truck, and was just shooting for some personal opinions and asking advise before i go shopping crazy. below is a list of what i'm planning to buy within the next month/2.
South Bend clutch rated for 700hp and 1200+ ft/lbs tq.
TS 6pos chip, running up to +140hp
K&N intake adding about 50hp (i hope)
i'm not sure which brand yet, but a 5'' turbo back exhaust
newer model headlights,tail-lights/towing mirrors
3'' leveling kit
ranch hand front end/rear bumper
any comments on those please let me know, and my overall question is:
1) Is it necessary to install a EGT sensor, i figured by putting a 5'' turbo back, i'm sure not to have a problem.
2) I've looked around on several websites trying to find fuel injectors at a reasonable price, shooting for 160cc stage 1 or 2 split shot injectors, anything over 50+hp and a link would be outstanding.
Thank you for helping out a rookie, i know there are lots of threads that could cover bits and pieces of this, but i'm practically looking for a diesel guru to take me under their wing and try to "school me up" at the moment my budget is 5k.
00'250 is offline
post #2 of 12 Old 12-03-2010, 06:22 PM Thread Starter
Anyone.....?
00'250 is offline
post #3 of 12 Old 12-03-2010, 06:42 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
I will respond to your PM. I would recommend a stage 1 single shot best for a DD with minimal mods and it will run nice and smooth.
2002 f250 BFT Edition
dereku is offline
post #4 of 12 Old 12-03-2010, 06:44 PM
Quoted: 3 Post(s)
gauges first!! Even with the 5 inch exhaust, you gotta have a way a monitoring whats going on in there. K&N is junk, better off going with the DIY intake setup, less money and better flow, and its not gonna be 50hp from an intake. TS chip would be good, but custom tunes would be better. You could probably do some reman stage 2's and get the custom tunes written for the single shots, and a regulated return and still be under the 5k budget.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 12 Old 12-03-2010, 06:44 PM Thread Starter
how about that EGT
00'250 is offline
post #6 of 12 Old 12-03-2010, 06:46 PM
Quoted: 3 Post(s)
Are you asking what EGT stands for?
2000 DRW CC 7.3
post #7 of 12 Old 12-03-2010, 06:56 PM
dereku's Avatar
egts will be nice and low with stage ones stage twos will put it a little high without a turbo upgrade but it is doable.
dereku is offline
post #8 of 12 Old 12-03-2010, 10:35 PM
Cjcross22's Avatar
Just get guages so you can watch your EGTs. They might never get too high but why chance it?
-Cory
Y2K
F250 XLT 7.3L ECSB SRW ZF6 4x4
Cjcross22 is offline
post #9 of 12 Old 12-04-2010, 02:02 PM Thread Starter
alright guys thanks, just wasn't sure if i really needed to monitor them with 5'' for breathing, but when i throw those injectors in, i've had advice to go ahead and do it. you guys are all right, better to be safe then sorry, lol
00'250 is offline
post #10 of 12 Old 12-04-2010, 02:14 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Probably gonna be good. I know autos better.
Get a custom tuned TS style chip. Same chip but with someone writing tunes just for what is on your truck. Much better.
NO! No intake adds "50 HP" but helps your truck breathe. A DIY is a good one.
You don't NEED it. But if you're gonna be going big big big later on, might as well now.
Gauges, always. For you, boost, EGT, and then maybe fuel pressure, coolant temp, high pressure oil gauge
Casserly, Rosewood Diesel to name a couple. Just google them.
If you're staying with the stock turbo, get an ATS ported shroud housing for the compressor. And maybe a 1.0 exhaust housing if you're going with bigger sticks. Adrenaline HPOP would be a good idea. Or a Terminator pump. Eventually a bigger fuel system. And bigger turbo. And it keeps going, and going, and going
I replied in "magenta"
4R100, 2wd
330,000 + miles
jesilvas is offline
