performance mods 99 F250 - Ford Powerstroke Diesel Forum
Old 11-30-2010, 03:47 PM
I have a 99 F250 and the mods done are a straight pipe, k&n, and a ts 6 pos chip. I just installed the 5.6k resistor mod and was wondering if anyone on knows if its ok to run this with a chip.......haven't ran it yet and was hoping for some input. Thanks guys.
Old 11-30-2010, 05:58 PM
the ts should make the resistor pointless. the resistor is simply lying to the computer about the oil pressure, the chip should command more oil based on it's programming.
Old 11-30-2010, 06:09 PM
the chip tells the computer to turn up the pressure, but wouldn't the resistor show a lower reading than what the chip is telling the computer????
Old 12-01-2010, 11:54 AM
Feedback Score: 5 reviews
Don't stack them...take it off. You may also want to get a different filter..
Old 12-01-2010, 11:59 AM
I have a k&n, and I cut the front of the grille out. It was blocking the snorkel on the intake.
Old 12-01-2010, 12:02 PM
any oiled filter is bad on a turbo.....anything
Old 12-01-2010, 12:47 PM
I need to know though, why not stack them? Why not get better throttle response, more hp, and possibly better mpg????
Old 12-02-2010, 10:01 AM
Cause you won't get it better..just jack your timing..these mods were developed when we didn't have good chips or tunes..
Old 12-02-2010, 04:06 PM
Thanks for the input guys.........you really helped out.....not doing the resistor
Old 12-02-2010, 04:10 PM
If you increase your HPOP twice, then you may blow seals, you pump, injectors, etc. . . .
