How many pounds of boost should i make? - Ford Powerstroke Diesel Forum
post #1 of 38 Old 11-30-2010, 12:52 PM Thread Starter
Poweystroke96's Avatar
I have a 2000 f-350 powerstroke with these mods:
Stage 1's or 2's (Not sure, had them in there when i bought the truck)
Edge evolution on level 3(100hp)
Its a six speed standard (not sure if it matters)
and i am currently making about 18 pounds of best at my best but usually around 12-15.
Is this normal or do i have a problem?
2008 f250 lariat ccsb
mini maxx with custom tunes
Sb intake
delete pipes with mbrp exhaust
Poweystroke96 is offline
post #2 of 38 Old 11-30-2010, 01:05 PM
Ron's power stroke's Avatar
i would think you should see 25 at the least... look for soot on the up pipes and chack all your boots and clamps..
Early 99 7.3 F350 auto,TN T-4 mount with a s467 thanks to unlimited diesel..shimmed 910's, DI push rod's, new alliant 315/200 hybrids, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
88 F250 7.3 IDI plow truck - bone stock
Ron's power stroke is offline
post #3 of 38 Old 11-30-2010, 01:12 PM
yup check for a boost leak. btw ditch the edge.
Dietoremain is offline
post #4 of 38 Old 11-30-2010, 01:40 PM Thread Starter
Want to badly but i need to put money elsewhere right now, gonna get a php FU2 chip when i get the chance.
Sb intake
post #5 of 38 Old 11-30-2010, 02:47 PM
I am making 18 pounds with these basic mods.... I dont know if that helps.... Cheers brian
2000 F350 SD XLT 4x4 7.3 Powerstroke Dually
AIH Delete,ISSPRO TEMP,BOOST,EGT Foil Delete. Wicked Wheel, DIY TYMAR INTAKE,Stancor GPR
grouser is offline
post #6 of 38 Old 11-30-2010, 02:54 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
you need to find out what kind of injectors you have before you get tunes. otherwise it will never run good.
2002 f250 BFT Edition
dereku is offline
post #7 of 38 Old 11-30-2010, 02:54 PM
big sig's Avatar
I see 25-30 with just exhaust, intake and php tunes. 30 is pushing it going up a mountain but 25 is normally at wot
mine
2002 F250 7.3l Powerstroke
AFE Stage 2 Intake
MBRP 4inch Turbo back exhaust straight piped
Autometer gauges z-series pyro, boost, tranny temp
PHP F.U. Chip
4 inch rough country lift, 315/75/16 mud grapplers, and procomp 1069 16x10
dads
2011 F350 SRW CCSB KR 6.7l Powerstroke
FB: Tyler Sigmon
big sig is offline
post #8 of 38 Old 11-30-2010, 02:56 PM Thread Starter
Then ill prob end up pulling one out to find out for sure.
Yah i definately think i have a problem.
Sb intake
post #9 of 38 Old 11-30-2010, 03:10 PM
hvprohop23's Avatar
I dont think you have a problem at all, i have a SuperChip set on the 100hp setting, with an S&B Intake and straight pipe and was seeing 18 max.. Now i have my wastegate unpluged and im hitting about 23 WOT
Ford F250 Ext Cab Short Bed 7.3L PowerStroke
S&B Cold Air Intake
ATS Ported Shroud Housing
Straight Pipe
Waste Gate Unplugged
Glowshift Gauges Boost, Trans, EGT
*DP Tuner coming soon*
And YES this is the sh*tiest looking hay you'll ever see
hvprohop23 is offline
post #10 of 38 Old 11-30-2010, 03:12 PM
Jonboywv12's Avatar
Send a message via AIM to Jonboywv12
im gettin around 25-30 with exhaust, intake, and chip.
Jonathan or Jon
2002 F-350
4" Banks turbo back exhaust.w/5" tip
4" Banks down pipe
Banks Big Hoss turbo waste gate
6" SKY JACKER
35" Nitto All-Terrains
TW chip 6 pos.
Banks Trans-Command shift kit
AFE STAGE II Intake
Gauges (boost, EGT)
102" whip antenna (guaranteed 100hp!
enough for fun!
Jonboywv12 is offline
