need help with exhaust - Ford Powerstroke Diesel Forum
Old 11-26-2010, 11:06 AM
i have a 2000 f350 and i just got an exhaust for it it is a mbrp 4 inch down pipe and into 5 inch i cant get the down pipe to fit has any one else had this problem
Old 11-28-2010, 05:18 PM
I had no problems at all. It went in extremely easy. Where are you having problems?
Old 11-28-2010, 06:02 PM
Mine slid right in. You can't get it to go in from the top of the motor, you've gotta come up from the bottom.
Old 11-28-2010, 07:36 PM
Its pretty tight but it should fit. and yea from the bottom up like ^ said.
Old 11-29-2010, 06:01 AM
PITA but they fit. have done a few, where you havin issues then we might be able to help.
Old 11-29-2010, 07:43 AM
It helps to have one guy under the truck holding the pipe and another on top of the engine tightening the clamp. Make sure to loosely install the entire kit before cranking down on the clamps.
