Forged Rods? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-16-2010, 07:56 AM Thread Starter
Forged Rods?
Ok so I have a 2000 f250, with a build date of 10/99. I always assumed that all of the 2000 year model trucks had forged rods but from doing a little more research im finding that that isnts always true. Any one know a rough build date for the cut off before they went to the PMRs? Can I take my VIN to a ford dealership and find out?
Thanks
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
Auto Meter Z series gauges
jimmyp is offline
post #2 of 11 Old 11-16-2010, 08:22 AM
Stroken7.3's Avatar
You have forged rods. To double check you need to pull the inspection plug out of the motor, it's on the driver side by the oil filter. You'll need a 5/16" piece of key stock about 2" long to take it out, the inspection is the lowest of the 2 plugs. Pull the plug out and look in the hole with a flashlight, you may need help barring the motor over to see a rod cap. IIRC the crank bolt is 23mm, when you can see the rod end look and see if it has a bolt head or a nut. If it has nuts (haha) it's forged if you see bolt heads you have PMRs.
2001 F-250, 6 speed trans, BDP Tunes, Autometer Ultralite gauges
Stroken7.3 is offline
post #3 of 11 Old 11-16-2010, 10:20 AM
layson's Avatar
Quoted: 82 Post(s)
Exactly what he said. You have to look to see for sure.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #4 of 11 Old 11-16-2010, 10:22 AM
Goose350's Avatar
Piston Rod info
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #5 of 11 Old 11-16-2010, 10:25 AM
Poweystroke96's Avatar
I've been told most 2000's don't have forged rods and its mostly 99's
Poweystroke96 is offline
post #6 of 11 Old 11-16-2010, 10:38 AM
Supporting Vendor
Instead of going on what you hear or read, go out and look.
It's the only way to be 100% sure.
PHPDiesel is offline
post #7 of 11 Old 11-16-2010, 11:04 AM
layson's Avatar
Quoted: 82 Post(s)
FYI... my 01 has forged rods...
Quote of the Day:
layson is offline
post #8 of 11 Old 11-16-2010, 11:11 AM
Oh I don't doubt it for a second. Going to see for yourself is the only way.
2008 f250 lariat ccsb
mini maxx with custom tunes
Sb intake
delete pipes with mbrp exhaust
post #9 of 11 Old 11-16-2010, 11:30 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
I am kinda glad that I have a E99 lol
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 11 Old 11-16-2010, 12:34 PM
Stroken7.3's Avatar
Don't rub it in. I checked for sure yesterday, guess what PMRs .
