edge evolution intermittent - Ford Powerstroke Diesel Forum
Old 11-08-2010, 03:41 AM
hello all
I just purchased a '00 PSD CC LB. It came with an edge evolution, 4 inch mbrp exhaust, and new stock turbocharger and pedastal.
the evolution was not loaded so I went to load it up and when I plugged it in it came up with an error saying that it could not communicate with the PCM. I fiddled with the OBDII port and then the evolution loaded. I set it to 100hp tune (race I think). I started it up after loaded and put my daughter in her car seat and drove off. the edge prompty shut off. I fiddled with the wires and it came on then went off.
any ideas?
Old 11-26-2010, 05:40 PM
My 99 is doing the same thing. It says unable to communicate with PCM, but no matter what I do, it wont work.
Old 11-26-2010, 08:23 PM
Check the fuse for the ciggarette lighter it also runs the OBDII port also.
Old 11-27-2010, 06:07 PM
The OBD2 cables on those are notorious for having connectivity issues. Get a new one from Edge before you lock up your unit while programming (which will require a PCM reflash if it happens...and your truck won't run).
Old 11-28-2010, 07:05 AM
A new cable or a new procrammer?
Old 11-28-2010, 07:24 AM
Read above.
Old 11-28-2010, 07:27 AM
Read above.
ah, gotcha. Thanks for the insight!
Old 11-29-2010, 03:11 AM
how much do the new cables run? I need to take that price and divide by 2 then subtract $10 and thats what I will tell my wife! ;-)
Old 11-29-2010, 06:00 AM
.........yea I had/have to do the same thing, and I would look at their website and check, er check with CT performance or Paul @ stealth both seem to have what u would need.
Old 11-29-2010, 09:53 AM
Call Edge directly. Usually, they'll just give you one.
