Cost!? - Ford Powerstroke Diesel Forum
Old 11-06-2010, 12:30 AM
Cost!?
Since my last thread turned out badly, I decided to make another one, hopefuly this time it will work.
As before I want to have the motor torn down and all parts I'll be re-using will be Acid Bathed. I wont re-use a whole lot, probably just the Heads, and the Block. Most if not all internals will be replaced with aftermarket counterparts which will for the most part will be stock. Aftermarket Crank, Drop Forged Connecting Rods, True Dual Exhaust, Cold Air Intake, Exct.
As far as Cams go I can't seem to find any aftermarket ones on the internet, heard overlap on a Turbo Diesel is bad, any information on that? As far as heads go too I can't seem to find any either. My goal is to make atleast 300hp and no higher than 350-375 safely. I still want a reliable daily driver/work truck with a weekend racer power.
What about Aftermarket Heads, haven't heard much about them.
