DIY boost fooler - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-04-2010, 04:11 AM Thread Starter
DIY boost fooler
alright guys with the TW chip installed, i can be cruising down the road in od at 70 (1900-2000rpms) and punch it and almost instantly hit 26-30psi of boost in the extreme setting. the street setting is almost the same.
Now I guess the next step is a boost fooler. I have done a search and cant find what im looking for.I have also tried to look at the thread in the mods section that every other thread get directed to and it wont let me watch the video.
So.... what I am looking for is some pics of what some of you have done for a DIY boost fooler, and an idea of what y'all are using for a pressure regulator. and how are you guys setting the 20-22psi numbers im seeing people are using.....?
thanks
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
Auto Meter Z series gauges
jimmyp is offline
post #2 of 13 Old 11-04-2010, 04:25 AM
i went to that site and got the same ,he says he no longer has the pin # to open the vid
Brucester is offline
post #3 of 13 Old 11-04-2010, 05:14 AM Thread Starter
Sweet......Sounds like it might be time to erase that thread then.......
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
jimmyp is offline
post #4 of 13 Old 11-04-2010, 07:05 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
yea he tryed to update it but it didn't work. but you can still get on you tube and see his old viedo.....I will try and find a link. I pmedded a mod to see if he can help. cause I built one and never understood how to "set" it.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 13 Old 11-04-2010, 02:34 PM
Lifetime Premium Member
jbeasts10's Avatar
You will have to connect the regulator to an air compressor.Basically set the pressure to 21-22 psi.Have the air flowing to the regulator..connect some sort of air tool..air nozzle..something that you can control(starting and stopping the air flow) on the out-flowing side.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #6 of 13 Old 11-04-2010, 02:42 PM
you could go to kenny at KT Performance and he has 2 or 3 different boost foolers that take 2 mins to install for less than 35 bucks.. and kenny is one heck of a guy
smokinyu is offline
post #7 of 13 Old 11-05-2010, 11:32 AM
j440's Avatar
I have basically the same mods as you, I ran an unplugged waste gate and a DIY boost fooler and my turbo toasted. I was hitting 30psi easy on my 140 tune. Stock turbos shouldn't be hitting that. I just finished rebuilding my turbo and have it back in and running now, plugged the waste gate back in and removed the boost fooler. Im going to make power the right way from now on
Late 99 ECLB XLT 4x4 F250 STOLEN..now recovered
-DP tuner
-DIY intake
-08 Mirrors
-Gauges
-05 Grille
-Smoked cab lights
-35s w/ no lift
-4" straight pipe
1997 CCSB XLT 2wd F250
-STOCK!!!!!!!!!!
j440 is offline
post #8 of 13 Old 11-05-2010, 09:35 PM
id just spend the 30 bucks from kenny at KT Performance and get a boost fooler, and just watch your boost levels.. the stock turbos cant hold up to 30psi for long periods of time...
smokinyu is offline
post #9 of 13 Old 11-05-2010, 11:25 PM
crdenoyer's Avatar
what fuel return kit do you have?? ATS??
Chris-2002 F250 7.3L CCSB Lariat:Leveled, WARN hubs, guages EGT TRANS and BOOST, 20" Liquid Metal Wheels, 33x12.50x20 Toyo M/T, '10 Tailgate, Bumper, 6000K HID's, Mag Hy-tec Trans and Rear Diff Covers, 4in TB Straight Pipe, AFE Stage 2 Intake, BTS Valve body, Casserly Stage 1's, GT38r, Reg Return, HPX, Comp Valve Springs, DP-Tuner Live tuned By Jody!!!!
crdenoyer is offline
post #10 of 13 Old 11-06-2010, 12:54 PM
whats kts website? or info? i am interested. and yeah i get cut off at 23 psi or so but i want a few more lbs but obviously i dont wanna blow up my turbo.
Dietoremain is offline
