couple of mod questions - Ford Powerstroke Diesel Forum
Old 11-02-2010, 04:05 PM
i have a 02 with 128,000 on it bone stock the fuel mileage is killing me and my goal is to gain some more mileage and a little more power with out spending a ton. So far i did the diy 6637 and next im going to do the muffler delete i dont think by putting a full system on it is going to make that much more of a differance i have been researching chips and i think im am going to go with a php tuner. this question prob has been asked before but with the chip am i going to take away from my engine and trannys life and cause premature failure to these? my truck still has a powertrain warranty for another 80,000 on it and if i were to put a chip on is it easy enough to take it out so no one would no i had it on the truck incase something major was to happen ? hopefully someone can give me there .02 cents on this
Old 11-02-2010, 04:28 PM
the engine can handle it fine its been way detuned. these things can take alot. the trans is the weak point. i suggest better cooling and a valve body to start1
Old 11-02-2010, 05:41 PM
A John Wood Or BTS valve body are probally your best bets there.
Old 11-02-2010, 07:06 PM
Whats your idea of "bad mileage"? I'd def do the straight pipe at the minimum tho...
Old 11-03-2010, 12:22 PM
im getting about 12-13 arond town and the best i can get on the highway is about 17 but usally 16.5 the muffler delete is def next
Old 11-03-2010, 01:20 PM
Sounds about right to me.
Old 11-03-2010, 03:18 PM
^It does? My old late '99 6spd never got below 17-18mpg city beating the **** out of it. Normally I got about 22mpg city though. I dont know what the heck you guys are doing to get that kinda mileage...
Old 11-03-2010, 06:02 PM
You also have a 4X2 thats has less wind resistance and less rolling resistance and weighs less than a 4X4. Elevation plays a big part in milage also, the closer to sea level you are the denser the air which = more oxygen and will give you better and more complete combustion.
Old 11-03-2010, 06:13 PM
Does anyone offer a tuner the goes threw my ob2 port that has custom tunes and also tunes the trans. I dont want ford to void my warrenty if something breaks beacuse they found evidence of one being on the truck
Old 11-03-2010, 06:24 PM
Use a custom tuned chip. PHP, TW, Beans, Gearhead, DP are what a lot of people run. I have a php. I really like it cause its switch on the fly and all you have to do is physically remove it to take it off. Takes 30 seconds to remove.
