12 volt source fir gauges - Ford Powerstroke Diesel Forum
Old 10-30-2010, 07:30 AM
Send a message via AIM to 350dieselsmk
Hey guys,
Im putting a 3in1 glow shift gauge in my friends truck. the harness has wires for a switched 12 volt source as well as a 12v battery source. can i tap both of those into the same switched source? Ive only installed auto meters and there is only one 12 volt source for them. if any one has input that would be great.
Thanks
Will
Old 10-30-2010, 07:33 AM
just run a constant to the battery and be done
the switched as probably for the lights or whatever
the constant will keep the memory and make it ready faster
if you must you can wire them to the same but its just as easy to run one fused wire
Old 10-30-2010, 07:41 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I drew my power from the battery.
I have a second smaller fuse block drawing directly from the battery under my dash. It is switched with a relay to the ignition wire.
Simple and clean for all my accessories.
