dieselsite intercooler boots and engine valley boots - Ford Powerstroke Diesel Forum
Old 10-28-2010, 08:02 PM
all my boots are leaking, (looks like to me anyway). dieselsite says the stock boots are silicone and the oil and fuel ruin them. they also say that the 7.3s have a closed crankcase vent system that lets oil into the air intake? does this make sense?
just wondering has anyone bought these boots? does oil eat away at them? they are quite expensive, is it worth it. is there a cheaper alternative? thanks for any thoughts
Old 10-28-2010, 08:17 PM
back to business
Yes, it makes sense. Except I hope there's no fuel coming in contact with the boots, that would be bad news going on somewhere.
The crank case vent enters the intake system pre-turbo and carries quite a bit of oil vapors, these vapors slowly coat the intake tubing, boots and intercooler with oil.
I have no experiance with the DS boots, but have heard good things about them
Also, look into a CCV mod. This will remove that oil from the intake by either venting to atmosphere, or filtering and returning to intake clean
Old 10-29-2010, 06:22 PM
Go with Riffraff diesel, cheaper than dieslesite, and dam good stuff
Old 10-29-2010, 07:40 PM
I have the Dieselsite boots, got them years ago. They are an awesome product. Id recommend them to anyone.
Old 10-30-2010, 02:19 AM
there still silicone boots and why would you buy a boot that you need to crank on the clamps so hard you crush the plenums then need his plenum inserts?? anything you put inside the flow of air will dirty up the air before it goes into the motor....i have dieselsite boots as well..there about 5 years old now...little more cash but well worth the $$,,, the pipes dont move a bit witch means no chaffing on wire loomes or powersteering bolts...mine have been sprayed with fuel,oil and power steering flued and there still holding strong with only 60 in/lb on a single clamp..
Old 10-30-2010, 03:35 AM
Coal Rolling = Posing
What he said.
Well worth it.
Old 10-30-2010, 03:44 AM
just a number
Buy this 1st .... that way there will be no oil in your new boots
CCV Mod
Old 10-30-2010, 04:37 AM
CCV Mod
Is this the same idea like a catch can on a gas motor?
Old 10-30-2010, 06:17 AM
the dieselsite boots are sweet! the ccv mod in the link above i have had going on 3 years and its a nice setup. you should buy both products as you will not be disappointed......
Old 10-30-2010, 01:02 PM
thanks for all the input,,i ordered the diesel site boots.
