TS chip install instuctions??
I have an 02 F350 and had someone install the TS chip a while back. Started having problems with the truck cutting out a few months ago and I run it on the stock setting with no problems. Some of the suggestions I have gotten is to clean the contact points. I was seeing if anyone on here had the original install instuctions for this chip. I was going to take the chip out and clean it and reinstall. Help me out!!!
thanks whitey!
When i did mine I took the screws out of the side of the PCM and you are able to get to the contacts very easy.
Check to make sure they cut out around the chip not just for the wire if so it maybe reading from the side and double check to make sure it is totally clean you can use a tooth pick
Did or have y'all noticed a very good increase in power after your install of this product? Have been looking at it and would like some feed back from those running it! Also, have you ran other chips/programs to compare this to? I have had the Edge Juice with attitude for a few yrs now and I am curious to see if this is a huge increase. According to the TS chips, they almost double to HP over the Edge.......Thanks in advance
TS 6 Install
I just puchased my TS 6 position chip with Bean's custom tunes.. I need pictures too show the best placement of the controll knob. can any one post pictures of their installs...Thanks
I didn't put mine in the dash, I have mine "loose" so when it comes time for another emission test I can hide it under the dash, cause the local shop dont like seeing them and will give you a hard time and tell you that they cant run it even if it is on the "stock" setting.
I put mine about 1/4 of the way to the left of the steering wheel on that piece of trim. Its nice and hidden but its easy to use. Im heading home and wont have computer access for the weekend but if you pm your cell number ill send you a picture of it
Took the chip out today and cleaned it up and reinstalled it and the truck runs great. The installer did a poor job. Cut a hole in the plastic that holds the PCM big enough that the chip doesn't get held in place. Was full of dirt. Cleaned well and put duct tape over chip.
