looking to make more power and still pass smog - Ford Powerstroke Diesel Forum
Old 10-24-2010, 12:16 PM
Chapter Director
ok so ive TW tunes 5in straight pipe DIY intake and still looking to make more power maybe 50hp more if possible
dont tell me injectors or bigger turbo because thats a no go here in cali and i dont have time to swap back to stock for smog checks, also cant gut the ebpv.
I was thinking of getting a Turbomaster from dieselsite.com to hold the boost pressure better and maybe doing water/meth injection. now what are your guys thoughts on this and whose got this setup... id say im making around 300hp now and would like to get into the 350 range. BTW ive got a BTS tranny so im not worried about any trans issues
any other suggestions on making more power?
Old 10-24-2010, 12:25 PM
Chapter Director
actually i might be able to get away with stage 1s if it will run on stock tuning and not blow any smoke, or a GT38r with the whole conversion to later style. just cant afford that right now
so what can i do in the meantime?
Old 10-24-2010, 01:01 PM
water meth is your best bet money wise..
sorry to say but turbo and injectors are next my friend..
Power levels..300 to 500 and above WHP ( write up )
Old 10-24-2010, 01:21 PM
Chapter Director
thats what i was afraid of... what kind of power can i expect from the wather/meth? i plan on it anyways to keep the egts down cuz im running right on the 1150* range when pulling hills, and it will get past 1200 if im not careful. but a power gain would be nice too
and IF i did have 3-4grand to spend and got stage 1s and Gt38r with proper tuning how much could i expect to make? 400?
Old 10-24-2010, 01:25 PM
stage 1 single shots and a turbo, return line, oil lines..chip etc youll hit 400
Old 10-24-2010, 02:07 PM
you can gut your ebpv. i did. im going to get the epbv eliminator when i need to 'smog' that way it'll tell the PCM everythings good. well depends who you go to if they look that close and care. Im not worried and i actually dont have to smog for another year so im good.
Old 10-24-2010, 02:15 PM
The Turbomaster wastegate is a nice unit, you can really dial in your boost. I bet your probally a hair over 300HP at your elevation. Tony can make you a smog tune if you do go bigger injectors, Last I heard the GTP38R is smog legal in California. Look on Garrets website and see if it has a CARB#.
Old 10-24-2010, 03:57 PM
Chapter Director
hhhmmm well in that case i may gut the pedistal, and get the eliminator thing or make something like it. do you notice any difference?
yea tony could but i dont think it would work cuz they pull codes and with a chip in it will throw a P0603 been there done that...
with stage 1s does it smoke alot? cuz right now it smokes to much for the local cops haha the bigger turbo should clear it up though right? what about just running the bigger turbo without bigger injectors?
an no one answered my question about actual hp gain with water/meth
Old 10-24-2010, 03:59 PM
hey man were are you getting smogged that simple mods would fail you? stage 1 and a drop in turbo upgrade would still allow you to pass as long as the smoke is in check.i passed with frx,hpx,turbomaster. i asked him about the ebv being gutted and he said unless its throwning a ses light visual would be fine since its not really a emmisions issue. granted this guy has been smogging me for years and hes a gear head himself he really only would fail someone who trys to sneak stuff by.
hit me up you can check out my current install and see just how stock i made it all look.
Old 10-24-2010, 04:02 PM
Chapter Director
my main goal is to just clear up some of that smoke. and pickup power in the process.
i get it smogged at monty's automtive, hes a diesel guy. but it just depends on which tech is doing the check. technically injector mods and upgraded turbo is illegal but they cant really tell if injectors have been change unless it pours smoke, and i figure as long as the turbo is a garret they wont notice if its change out.
