need install help with riffraff plenum boots - Ford Powerstroke Diesel Forum
Old 10-22-2010, 07:23 PM
im working on installing the plenum boots and have ran into a couple issues. given the boots length they are running up the spider leg further than the stockers, this is causing a issue with the clamps. should i clamp further up the leg? by chance does anyone have some install pics? i talked with clay since i had an idea about cutting them down a little but hesaid not to.
Old 10-22-2010, 07:28 PM
no i didnt cut them to get mine on. i just put them on about where they would be on the stock ones. and havent had any leaks yet will try to get a pic to u if i can tomorrow
Old 10-22-2010, 07:33 PM
with the boots slipped all the way down on the plenum theres still alot of hose on the spider leg,past the normal clamp point.
Old 10-22-2010, 07:39 PM
i just clamped it down and left the excess there. like i said no leaks and run 24-25 psi
Old 10-22-2010, 09:52 PM
but did you clamp it at the stock place or further up the leg of the spider?
