Zoodad Mod - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-22-2010, 03:20 AM Thread Starter
Zoodad Mod
I know what the Zoodad Mod is and how to do it. But I'm a little fuzzy on the mechanics of it. It seems to me that if you drive your truck in the rain at all it will suck up a bunch of water. If I'm wrong let me know because I really am considering do this mod. And if the thread is already out there on this issue send me a link please cause I couldn't find it anywhere. Thank you for your help in advance.
chrisgrimes2186 is offline
post #2 of 12 Old 10-22-2010, 03:29 AM
taskforcefreddy's Avatar
The thread is out there... like dozens of times. You can mitigate the rain/water problem by putting some scrfeen-door material over the hole that you cut. Thousands of people have done this and I don't think I've read of one case where rain/water was ever a problem.
taskforcefreddy is offline
post #3 of 12 Old 10-22-2010, 03:35 AM
jtk27's Avatar
Was going to post this same question this morning. I decided against the zoodad because of the risk vs. reward. Rain, car wash, washing out radiator, etc. all seem like they could harm air filter with zoodad. I've also seen filters with a bunch of bugs in the air filter from zoodad. I was all set to do this mod even found a cool screen cover for the hole but after considering all the things above what do you really have to gain? With the water concerns I wasn't all that concerned with water making into the intake but more the degradation of the filter itself over time.
05 F250 King Ranch PSD 4x4
-ARP head studs with factory ford gaskets
-Updated oil rail plugs
-Liberator diesel Y-pipe
-SCT X3 Custom tuned by Eric
-Dieselsite Coolant filter kit
-High Idle Mod
-Edge Insight CS w/EGT
-Sinister EGR Delete
-Prestige Remote Start
-Upgraded turbo drain tube
-Upgraded HPOP connection
-Blue spring kit
South Central Oklahoma Ranch Hand Accessory Dealer
jtk27 is offline
post #4 of 12 Old 10-22-2010, 06:31 AM
smokenstroke's Avatar
Quoted: 8 Post(s)
Ive never seen water in mine. I was worried when i first did it. Every rain for a while after i did it i would check the box. No rain ever even made it past the hole that you cut. Drove in rain down the interstate, snow, sleet, whatever. Never any problems. Did see a thread somewhere i guy didnt put a screen and he sucked a bird into his. Dont know if its true but thats what i read. But rain is not a worry at all.
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
smokenstroke is offline
post #5 of 12 Old 10-22-2010, 07:50 AM
Well, I just installed the Ford AIS and the plenum goes directly to the grill and is pretty much a straight shot to the airbox. There are weep holes in the bottom of the airbox to let any water drain out, so I don't think that would be a problem. I haven't had it long enough to know about bugs
12/98 E-99 CC Long Box 4WD Dually Lariat, Banks IC/Wastegate/6-Gun........Heated/Cooled Cupholders
Degnol is offline
post #6 of 12 Old 10-22-2010, 10:00 AM
Snake's Avatar
Quoted: 47 Post(s)
I've had this done on my 6.0 for probably 120k miles. I've been in snow and sleet up north. And torrential downpours in FL for the past 4 years. No issues with my AiRaid intake yet (knock on wood).
Snake is offline
post #7 of 12 Old 10-22-2010, 11:36 AM
Unless you spray water in there with a hose at full blast for minutes at a time... The box has drain holes to take care of that. If you get that much water in there you have bigger problems. As for the bird, I needed a good laugh.
SOLD 97 F250HD Extra Cab, SWB, 2wd, Chipped, Piped, Intaked, Intercooled, Gauged, Clutched and other stuff I forgot. Good by old friend.
2001 F350, CC, SRW, 4x4, LWB, F650 dash, PHP Hydra, AIS, Gauges, John Wood Trans, 6.0 transcooler, IH SS down pipes, Summit 4" exhaust, Zoodad and a list of "To do's".
lcowner is offline
post #8 of 12 Old 10-22-2010, 02:46 PM Thread Starter
Well ok, Sounds like I will give it a shot and put some really small screen wire behind some thicker screen for stability. I really like the write up on the gutter ends. Sounds like a plan to me. If I get water in my engine I'm going to blame everyone in this thread except for jtk27. lol
post #9 of 12 Old 10-22-2010, 02:52 PM
Other vehicle is an F250
Hank's Avatar
I did mine this way and named it!
HankDaddy (Holeless Zoodad)
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #10 of 12 Old 10-22-2010, 07:38 PM
lol thats what lead me to do mine i hit a bird and when i got home found the bird wedged in where the mesh is so i just cut the other side out to match
2000 F350 lariait CC lwb 4x4. 307,xxx fresh tranny.superchip,DIY intake,foil delete <--joke. straight piped.
1990 f150 351,AODe, 256,000.SOLD
1999 Mustang GT 35th anniversary, 169,000
i am a testament that fords are the longest lasting vehicles.
[B]2000[B] Volkswagen Beetle 1.8T 5spd. my DD
I BLEED BLUE!
8lugs8feet is offline
