help on FRx install - Ford Powerstroke Diesel Forum
post #1 of 16 Old 10-03-2010, 06:36 PM Thread Starter
help on FRx install
alright, i'm having quite a bit of trouble with the driverside plug, it wont budge for the life of me, i've soaked it in PB blaster, i even removed the bolt just in front of it, but its to close to the up pipes that i cant get a socket wrench in there or a bolt out tool, and ideas? the passenger side one was actually much easier, i didnt even have to remove the ac..... any help would be appreciated
matter is offline
post #2 of 16 Old 10-04-2010, 05:04 PM
Hoverp's Avatar
Just did mine today.
Please go purchase a 5/16 8 point socket I was able to easily get the socket on the driver side rear port plug easily with the 8 point 3/8 drive socket.
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #3 of 16 Old 10-04-2010, 06:51 PM Thread Starter
i had it on there the first time and it was slipping, after a couple of day of frustration, some still bloody knuckles, i went back in there with a very bright light, and vise gripped the **** out of it..... I WIN!!!
matter is offline
post #4 of 16 Old 10-04-2010, 08:47 PM
Hoverp's Avatar
good on ya!
after getting mine installed I didnt notice any difference in the "cackle" noise from Number 8...did you?
Hoverp is offline
post #5 of 16 Old 10-05-2010, 02:35 AM Thread Starter
it was very late when i did get it in, plus im doing some other things as well, so i'm not completly done yet, but i never noticed a "cackling" noise at all, i'm doing this as a longevity thing
matter is offline
post #6 of 16 Old 10-05-2010, 05:50 AM
Quoted: 3 Post(s)
I just did mine on sunday, I had the opposite problem. Drivers side was easy, didnt even remove the intake, the passenger side... I had to remove the ac, and the tensioner assembly. I do think my truck sounds quieter though at idle
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #7 of 16 Old 10-05-2010, 05:50 AM
Hoverp's Avatar
Ive got the Riff Raff HPx I might try that one today....also got the WW but a bit afraid to do that one during hunting season...I neeed my truck!
Hoverp is offline
post #8 of 16 Old 10-05-2010, 06:00 AM
Hoverp's Avatar
I purchased a 5/16 8 point 3/8 drive socket and had a 3/8 universal joint... that combo worked real easy on the forward passenger side. It wouldnt have without the universal though.
Did you do the HPx yet? If so any lessons learned on that install?
Hoverp is offline
post #9 of 16 Old 10-05-2010, 11:58 AM
Quoted: 3 Post(s)
yeah I did the HPx as well, its a really easy install, I didnt remove anything to do it, just used wrenchs to remove the oil plugs, then install the ones from the kit. the instructions say to remove alot of intake stuff but you can get your hands in there.
2000 DRW CC 7.3
post #10 of 16 Old 10-05-2010, 02:35 PM
Hoverp's Avatar
Yep, just gone done with that...way easier than the FRX...I did notice my rig seems smoother and a bit quieter now....more from the HPx than the FRx... for some reason...
But Im happy and the installs are not leaking a bit....never really had any significant seepage from the oil ports at all when I did mine..no more than a capfull.
Hoverp is offline
