Injector questions - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-02-2010, 07:47 PM Thread Starter
RHFDpowerstroke53's Avatar
Injector questions
If i were to put stage 1 Injectors would i have to reprogram my pcm? is there anything i need to do. I have heard about a fuel return system. Im not sure. Help is appreated. Thanks
2001 F-350 XLT
'05 Conversion
DP-Tuner
Tuff Country 2.5in Leveling Kit
MBRP Muffler Delete W/ Homemade 5in tip
aFe Stage 2 Cold Air intake
Wicked Wheel
315/75R16 Mickey Thompson Baja MTZs on Procomp 6001s
RHFDpowerstroke53 is offline
post #2 of 11 Old 10-02-2010, 10:31 PM
if you go with single shots then yes you will have to get some tunes. imo stage 1's are pointless. go with the st 2's 160/100's. and there are people runnin 250/100's on stock fuel system but it never hurts to have one
bruce51d is offline
post #3 of 11 Old 10-06-2010, 05:17 PM
Stage II's w/ just a tune and supporting mods (ie intake/exhaust)? What kinda power will the 7.3 put down w/ a good tuner, intake, and exhaust? (Sorry I"m a bit cummins washed still.. trying to remember my PSD roots).
85_305 is offline
post #4 of 11 Old 10-06-2010, 06:08 PM
BraveHeartCalif's Avatar
U may want to research a 175/30 byfull Force. Enough power upgrade with out going over the line in reducing your reliability on the entire vehicle imo.
BraveHeartCalif is offline
post #5 of 11 Old 10-13-2010, 08:34 AM Thread Starter
Also. I have heard bigger injectors will wash down my cylinder walls. Is this true or no?
And how much is it if i had Ford do the job it with stock injectors?
2001 F-350 XLT
'05 Conversion
DP-Tuner
Wicked Wheel
post #6 of 11 Old 10-13-2010, 08:36 AM
They will only wash down the cylinder walls if you dont get the right spray pattern (this is more common with marine 360's on 12v cummins). Ford will probably charge MORE to refurbish your oem sticks as it would cost for hi performance aftermarket sticks.
85_305 is offline
post #7 of 11 Old 10-13-2010, 10:36 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
x2
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 11 Old 10-14-2010, 09:04 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Stage 1's are a great mod for a SD, will get you 350-380HP, better MPG's and will require less mods to run. stage 2's..up to 450HP but will require a new Turbo and a built trans etc if you want reliability.
We are a Cass-Full force dealer PM if we can help.
Cary
CT Performance, Inc. is offline
post #9 of 11 Old 10-14-2010, 11:44 AM
That sounds a bit more accurate. I was thinking that stage II sticks with a stock snail wouldn't work out.
85_305 is offline
post #10 of 11 Old 10-14-2010, 01:23 PM
Quoted: 3 Post(s)
Well not for long!
