INTERCOOLER HELP AGAIN!!!! HELP@!!!!!
okay,does the intercooler sit in front of or behind the condenser? and if it sits in front,were does the hood latch fit in all this?? the hood latch is in the way of the I/C laying flat against the condenser...is ther a write
I think its sit behind
i think its behind......
i know a guy that put an intercooler on his OBS and im pretty sure his was infront of it though.... so im not 100% sure on either way i do know that his was visible through the front bumper, if that helps at all |
wrong section harley
Yea if you have a OBS as Jarod said.. U should to go to the other section
![]() but for NBS im perdy sure it sits behind Last edited by BraveHeartCalif; 09-27-2010 at 10:56 PM. |
well on a sd i think its on top. the ic is lower iirc.
obs trucks you gotta make it fit
yea, OBS truck, make it fit....
My condesor sits behind the IC. Remove the brackets from the condesor, flatten them out ![]() ![]() Remove teh hood latch and its support bar. Cut the support bar, and weld in a piece of Flat stock... ![]() When you cut through the rad. support for the intercooler pipes, be sure to cut the holes big enough.
