Which "Boost Fooler" do you run? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-26-2010, 07:15 AM Thread Starter
Hoverp's Avatar
Exclamation Which "Boost Fooler" do you run?
Im looking at 2 different types
1. The electronic type that plugs in and works with the MAP sensor
2. The mechanical type that regulates what the MAP sees mechanically.
Which type do you run and why?
Advantages or disadvantages to either type?
Price is NOT an issue, reliability and system integrity are!
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #2 of 16 Old 09-26-2010, 07:22 AM
I looked at two different ones, the itp one and one that i found off of ebay i think i searched boost relief valve. i ended up going with the ebay one because it is mechanical just as the itp one is but it has two connections one on either side of the valve so that i could hook up my boost gauge and it would tell me my actual boost or i could go to the other side and see the boost that the map sensor is seeing. it was also relatively cheap, i think around fifty bucks or so
early 99 F250
ZF6
its stock, at least thats what i tell people
whitelightning150 is offline
post #3 of 16 Old 09-26-2010, 12:28 PM
BraveHeartCalif's Avatar
i got the mechanical one.... i dont ever think its smart to mess with the electronics...
BraveHeartCalif is offline
post #4 of 16 Old 09-26-2010, 01:31 PM
Quoted: 3 Post(s)
i got the dieselsite on, had one on my last truck too, never let me down.. although i dont even make enough boost on my dually to set off the ses
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 16 Old 09-26-2010, 01:40 PM
02stroker250's Avatar
i just went to lowes and got a air pressure regulator and set it on a compressor to only let 23 pounds of air threw it i like that way alot better than the eletronic way
2005 F-250 ccsb fx4
02stroker250 is offline
post #6 of 16 Old 09-26-2010, 05:25 PM
Lifetime Premium Member
jbeasts10's Avatar
+1..on the air pressure regulator.No issues.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #7 of 16 Old 09-26-2010, 06:21 PM
Flapdisk's Avatar
What do you guys actually do with the pressure regulator? How does it work and does it actually make a difference? I am really interested in this... thanks in advance
Flapdisk is offline
post #8 of 16 Old 09-26-2010, 06:37 PM
Koda22's Avatar
Quoted: 5 Post(s)
im so lost im still new to the diesel world and not sure wat this is....
Koda22 is offline
post #9 of 16 Old 09-26-2010, 06:40 PM
jbeasts10's Avatar
You set the regulator to 21 to 23 psi..( it mounts in-line on the Map sensor hose).Flow towards the Map sensor.Very simple set-up
It keeps the computer from seeing more than 21 to 23 psi of boost.
post #10 of 16 Old 09-27-2010, 06:04 AM Thread Starter
Hoverp's Avatar
Insnt this the same basic setup from IDP(Sinister Diesel)
Hoverp is offline
