zf-6 clutch - Ford Powerstroke Diesel Forum
Old 09-22-2010, 07:40 PM
zf-6 clutch
just picked up a e99 f-250 2x4 with a 6-speed, it has 475,000 miles and a bad rear end. i plan to just use it as a work truck, with a few minor mods, for example intake, chip, and exhaust. my question is how far can u push a stock clutch? i know it all depends on how u drive it and what condition it is in. how far have you pushed it before you had it slip.
Old 09-22-2010, 09:31 PM
you dont think its original do you?
Old 09-22-2010, 10:58 PM
With that many miles, even if it's been replaced once or twice, it's not a good idea.
You're better off getting an upgraded South Bend or Valair clutch rather than risking a clutch exploding (worst case scenario) and causing you to need a new transmission as well.
Old 09-23-2010, 04:24 AM
don't now when it was replaced, i bought it off my buddy's company he should have it on record of when it was replaced, if at all. i was more curious as to how far other people have pushed it.
Old 09-23-2010, 05:47 AM
my truck has about 200,000 and its on its third clutch. It slips in 6th gear only if I shift from 5th getting on it. But if let off it stops slipping and wont slip again.
Old 09-23-2010, 02:54 PM
If your worried about it make it the first upgrade you do. A chip and intake do no good if the truck can't move or clutch slips with the slightest power adder.
Old 09-25-2010, 01:35 AM
ran mine for about 130,000 before replacing. dont do much towing with it though
