Installing the Raccor Fuel Filter/Separator - Ford Powerstroke Diesel Forum
Old 09-21-2010, 10:29 PM
I got the raycor 320r-rac-o1 Marine Filter/Separator in the mail w/ the Ford tranny kit xc3z-7b155-e since it has all the parts i need except the fuel hoses. Which ill get tomorrow before i intall. To be installed inline before the fuel pump on the fuel rail. It looks small in the picture but it is big.
Installing the Raccor Fuel Filter/Separator-racor.jpg
Old 09-22-2010, 08:13 PM
Had to fabricate a bracket for the Outboard Marine Racor Fuel/Water Sep. Filter for my 7.3
Installed without a hitch and its working swell... I put it pre the fuel pump on the rail. Im very happy with the results
Installing the Raccor Fuel Filter/Separator-filter1.jpg   Installing the Raccor Fuel Filter/Separator-filter2.jpg
Old 11-12-2010, 06:20 AM
I'm about to install a similar filter on my 02'.
The question I'm pondering, is how to best reprime the filter when it gets changed? Will cycling the OEM fuel pump do it alone?
I see Racor offers several models with built in pumps. One line, the 400R series, offers a manual pump.
I really want to extend the life of my injectors, and I think retrofitting a Racor filter/separator with a 2 micron element is the best route.
Old 11-12-2010, 03:12 PM
put the racor pre the fuel pump down the rail. add fuel to the filter as much as you can. Then screw it on and turn on the ignition withoutstarting the vehicle for about 20 secs. then shut off. Do it about 3'x then start and u should be good to go.
Old 11-12-2010, 05:06 PM
Thanx, that sounds simple enough. Off to ebay I go to make a purchase.
One more question.... Where does that extra air go? Say there's a few cubic inches on air in the filter that I just couldn't get out by pre-filling the cartridge. Eventually that air makes it to the OEM filter/separator bowl, but where does it go from there? Is it routed back to the tank?
Old 11-12-2010, 09:55 PM
The extra air gets pushed out to the fuel bowl then out the injectors. if u do it this way as shown there wont be any air pockets left in the fuel system. The Racor really keeps the fuel filter under the hood clean as a whistle. My Ford Mech told me in all my years, that i have the cleanest fuel bowl hes ever seen on a 7.3
U can thank the Racor for that
Its one of the best preventative main mods ive done. Very happy with the product and the results...
U will most likely have to custom make a bracket. But worth it imo
Old 11-13-2010, 08:49 PM
Looks good. Where did you get the racor?
Old 12-28-2010, 07:03 PM
Install Racor filter
Instead of using the tranny kit, could i just use two barbed fittings with hose clamps? Is there anything special in the tranny kit.
Thanks
Old 01-06-2011, 08:41 AM
Racor Filter Adapter
Hey 2000REX I agree with you, I don't see why you can't just go buy two 1/4" NPTF fittings and use thoses. Instead of buying the filter from FORD.
