Never modded a diesel
Like it says I have modded a ton of things and built some bad a$$ cars but I have never touched a diesel myself (other than maintaining it ). I had a 2000 that I paid to have mildly built and loved it . I have an early 99 7.3 . It is all stock except I strait piped it . No kitty and no muffler . It dumps at the back of the cab . It has a Super Chips programmer set to heavy tow . I am going to install gauges (trans , pyro , and trans temp ) . After this what should I do . I am not looking to go crazy , just make some more power and role some coal . My truck doesn't smoke a bit now . Are there any free mods like on Stangs ? I want to do all the mods then get my tune so I can tell the tuner everything and be done with it for now ......
. I know , never done .
intake and if it's not then 4 or 5in exh, then a custom chip, then trans (valve body or fully built) then HPOP, sticks (injectors), turbo.....idk what else I am sure others will chime in. most of all have fun.
It doesn't smoke with that tuner..put a TS chip with custom tunes on it and it will..We have TW and Cales tunes..also the other parts you need. If I can help..PM.
Cary |
Very first is gauges
Intake and exhaust then maybe a chip Boost fooler AIH delete Then if you tow you will have surge, so a wicked wheel, ATS housing, or turbo Larger injectors for that turbo oops... toasted trans... BTS time Water or propane larger injectors . . . |
E99 no AIH, tuner after gauges and exh/intake so you can have it re-done for other stuff, just a cold air intake intake manifold isn't worth $$ (thats what I have been told). agree with trans cooler (I need to get one
) and converter how about a valve body? and water/meth is a good thing for these trucks if you do alot of towing. lastly yes E99 has WW but also we have smaller intercooler tubes and diff turbo. ok now I am done, hope this helps.
When I first got my E99 it wouldn't blow even a puff of black smoke. Even with intake and exhaust. Then I put my TW chip on and now it'll black out a street. Sometimes I feel bad for the people behind me when I'm merging on the interstate.
Thanks for the info , I was wondering about that . By the way , I like the Bronco . I miss mine .
