Pyro Probe Location? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-26-2010, 07:48 PM Thread Starter
I installed the Pyro Gauge and my Boost Gauge tonight, the boost is working well, but I have yet to install the actual Pyro Probe. Where is the best place to mount this. It does not appear that it is possible to mount it in the exhaust manifold as the prob is about 3" long and the manifold is only 2.5" or so.... I was thinking in the exhaust downpipe right after the turbo??
2012 F-250 Crew Cab
2002 F-350 Crew Cab SRW (Gone but not forgotten)
4x4
6 speed
DIY Intake
Custom 6637 Pre Filter
4" Turbo Back Hog Performance Exhaust
SCT Multi-Position Chip
Iss Pro Gauges
2" Leveling Kit
285/75/16 BF Goodrich AT's
FRx Fuel Rail Crossover
HPx High Pressure Crossover
OCR Boost Fooler
CCV Mod
Turbomaster Actuator
Rough Country Dual Steering Stabilizer
16x9 Moto Metal Wheels
WISH LIST: 05-07 Conversion
tysonmatc2 is offline
post #2 of 8 Old 08-26-2010, 07:56 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Drill and tap the drivers manifold at the back right where is starts to bend. It will fit there and give you the most accurate reading. Is your probe the type that threads into the manifold or has a clamp that holds it on?
dhanna6powerstroke is offline
post #3 of 8 Old 08-26-2010, 08:02 PM Thread Starter
Thanks, it threads into the manifold.
2012 F-250 Crew Cab
4x4
6 speed
DIY Intake
Iss Pro Gauges
2" Leveling Kit
OCR Boost Fooler
CCV Mod
post #4 of 8 Old 08-26-2010, 08:05 PM
Mod Newbie
Quoted: 19 Post(s)
Is the probe adjustable through the fitting that goes into the manifold?
post #5 of 8 Old 08-26-2010, 08:09 PM Thread Starter
I don't think so but I will have to look tomorrow at the shop. I know there is a nut that threads in the the manifold and then the probe screws onto that nut I believe. I bought it used off a guy that had it on his Excursion with a 7.3
2012 F-250 Crew Cab
4x4
6 speed
DIY Intake
Iss Pro Gauges
2" Leveling Kit
OCR Boost Fooler
CCV Mod
post #6 of 8 Old 08-26-2010, 08:14 PM
Mod Newbie
Quoted: 19 Post(s)
You should be able to thread the one piece into the manifold and the slide the probr where you want it (needs to be as close to center of the inside of manifold as possible) then take the nut and tighten it down to hold the probe in place. It might be a little different than that but you should be able to adjust it somehow.
post #7 of 8 Old 08-26-2010, 08:14 PM
jesilvas's Avatar
Quoted: 2 Post(s)
They fit into the manifold fine. Got mine right there and didn't have a problem with it hitting the other side
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 8 Old 09-03-2010, 03:25 PM
the probes use an NPT (normal pipe thread)
pipe threads are angled 60 degrees and tapered. The taper will prevent the probe from entering too far. There probably wont be an adjustment on the depth of your probe, but you shouldnt need it.
2000 7.3 F-350 Super Duty Dually. FULLL PULLLL
EscaladeSteve is offline
