fuel in water light chip install - Ford Powerstroke Diesel Forum
Old 08-22-2010, 08:59 AM
water in fuel light on after chip install
i installed a chip into my 2001 7.3 it runs fine but now i have the water in fuel light staying on will this harm my truck everything seams to work fine m
Old 08-22-2010, 09:59 AM
Drain the fuel bowl to make sure there is no water in it and make sure the connector is in tight
Old 08-22-2010, 10:13 AM
when i pulled the chip off the light went off i was wondering it it do any damage to run it with the chip in
Old 08-22-2010, 10:23 AM
No probably not.
Old 08-23-2010, 10:05 AM
Most common effect when the chip is not programmed for the correct code.
Old 09-30-2010, 10:59 AM
I know this post is old but i have the same problem except when i pulled the programmer out of my truck the light is still on and i have a huge loss of power/horrible acceleration. I changed my fuel filter and drained the bowl and didnt see any water. WHAT DO I DO?!?! The programmer was installed and de-installed in the matter of an hour because i didnt like when the light came on but now its been on for a week and a half with no programmer whatsoever?!?!
