Installing a Fuel Gauge? - Ford Powerstroke Diesel Forum
Old 08-16-2010, 10:00 AM
Power Stroker
Send a message via Skype™ to stroking 7.3
I want to install a fuel gauge. I don't even know where to start. I am a wana be DIY. Don't know much yet but am learning with every project. I have installed a FRx. Under the hood gauge will be fine. Need gauge recommendations, and what do I hook it too?
Old 08-16-2010, 04:25 PM
back of the fuel bowl lower right (from the front of the truck) is a plugged port, -4 or -5 ORB fitting, you'll need a ORB to NPT adapter then a NPT 90* and then the gauge will be in the valley but visible just over the fuel bowl
Old 08-16-2010, 04:35 PM
Anyone got any pics of what this looks like where it mounts.
Old 08-16-2010, 08:57 PM
I found 2 pics
be aware, this is only good for setting and checking idle fuel pressure, which is not the most useful, I had mine in for 2 years or so, then I got an isolated in cab fuel pressure gauge and found my pressure was dropping significantly under load.
Old 12-02-2010, 12:41 PM
Originally Posted by Phiber Optik View Post
I found 2 pics
How would I go about doing this (see in red) I am curious about my pressure under a load as well. Some times the truck just doesn't feel right when I put it under a load. Thanks.
Old 12-02-2010, 02:43 PM
Dont... get an electric fuel pressure gauge and be done... Once, right and safe.
Isspro, or Autometer, but I am partial to Isspro.
Old 12-02-2010, 02:50 PM
the isolation diaphram with gauge works great for me, I don't have to worry about a transducer failing, or a voltage problem skeuing the reading.
or if you just want to make one temporary to go under the wiper, you could do it really cheap in ipex (plumbing pvc) and then remove it after you find out what your pressure is under load, ipex is good for 300psi I believe
Old 12-02-2010, 05:15 PM
If I was to put a permenant gauge in the truck, Does any one make a cool single gauge pod for the truck? I already have the three gauge pod and don't want to scrap it just to go buy a four gauge pod? Thanks.
Old 12-02-2010, 05:50 PM
Steering Column pod works slick.
Old 12-02-2010, 05:52 PM
I like that idea!You know off the top of your head where to get one or should I just google it?
