diy intake question - Ford Powerstroke Diesel Forum
Old 08-15-2010, 05:44 PM
Send a message via AIM to mxracer511 Send a message via Yahoo to mxracer511
diy intake question
this may be a stupid question but when doing the diy intake the 6637 filter is that the same part number that i would get from o reillys or autzone or something only asking cu the closest napa is about 2 hrs away any help would be appreciated thanks guys
Old 08-15-2010, 08:43 PM
I bought a WIX 6637 from the local O'Riellys and it has worked great. You might want to google crossreference the number, as I know it wasn't just "6637" there was a letter at either the beginning or end of it if I recall correctly.
Old 08-15-2010, 08:59 PM
Baldwin PA2818 works too.
Ok sounds good and thanks definitely appreciate the help
Old 08-15-2010, 09:16 PM
Napa has decent prices if you need it absolutely now. The Napa number is 6637 and the Wix number is 46637
O'Reilly's price at $54.99 sucks.
Here's where I got mine $36.79
Baldwin PA2818 Element Air Filter
Came 2 days later too
Old 08-15-2010, 09:35 PM
i started a diy cold air intake out of a aluminium tool box top[IMG][IMG][IMG][/IMG][/IMG][/IMG] sorry if its not right this is my 1st post. im not done with it yet. i have to finish later i have to tig the corners and cut a couple of more peices
Old 08-15-2010, 09:38 PM
I will try this again!
diy intake question-aaairintake1.jpg   diy intake question-aaairintake2.jpg   diy intake question-aaairintak3.jpg   diy intake question-aaairintake4.jpg
Old 08-15-2010, 09:41 PM
will post more when it is all together and sealed
Old 08-16-2010, 08:10 AM
SJB SJB is offline
I went with an Amsoil 4095 filter over the traditional 6637 filter. The Amsoil is a non-oiled filter that is washable/reusable and fits in there perfect. It has a spot to mount your air restrictor gauge and has a built in bolt to mount a holding bracket (I used a straight piece of metal and bent it into an L-shape to hold it in place). The filter w/ a pre-wrap cost me something like $75 shipped (but I'm an Amsoil Preferred Member for only $20 per year). I thought it was a better investment over the one time use 6637.
Old 08-16-2010, 08:17 AM
I bought mine from O'Riellys for $30
