Performance Options - Ford Powerstroke Diesel Forum
post #1 of 24 Old 08-08-2010, 02:56 PM Thread Starter
Performance Options
I have an early 99, that im swaping in a 02 7.3 into...so far I have a fuel cross over, (ww, 1.0 exhaust housing and high flow outlet), tymar intake, 5" exhaust, and eventually beans custom tuned chip...what other mods would you recommend for performance?
99blackdually is offline
post #2 of 24 Old 08-08-2010, 03:01 PM
Raul@Stealth Automotive's Avatar
not performance but if its an auto i would put a large 31 row 6.0L trans cooler, gauges.. for your trans i would do a upgraded valve body and a torque converter...
for performance your going to have to step up to a better turbo and injectors..
nothing "big" you can do to get more performance after a chip, intake and exhaust thats cheap...
-Raul
Raul@Stealth Automotive is offline
post #3 of 24 Old 08-08-2010, 03:10 PM Thread Starter
yeah I already have a valve body, and the truck already has dual tranny coolers, and eventually i might go ahead and put a tq in it but for now im going to wait on that
post #4 of 24 Old 08-08-2010, 03:12 PM
ah k then your pretty much set after the chip... with stock injectors your kind of stuck at the 320hp to the wheels range no matter whos tuning you use....
1 more thing i would add is a CCV mod....
-Raul
post #5 of 24 Old 08-08-2010, 03:13 PM Thread Starter
where should i get that, and what does that do?
post #6 of 24 Old 08-08-2010, 03:14 PM Thread Starter
it has pmr, im sure, what about meth/nitrous/propane??
post #7 of 24 Old 08-08-2010, 03:19 PM
you either make one yourself or get one here:CCV Mod
im not a big fan with playing with juice.. IMO if your going to spend the money just do it right... stage 2 hybrids, bigger pump, 38R and custom tunes... that will get you to the 400hp to the wheels range....
post #8 of 24 Old 08-08-2010, 03:25 PM Thread Starter
thanks for the advice, does anyone sell a converter lockup switch that comes with instructions and is easy to install?
post #9 of 24 Old 08-08-2010, 04:18 PM Thread Starter
anymore opinions from other experts??
post #10 of 24 Old 08-09-2010, 02:25 PM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
PMR's no larger than stage 1's unless you swap the rods. Good drop on turbo for 1's..D66.
CT Performance, Inc. is offline
