ie sometimes while idiling and misses while driving HELP ASAP - Ford Powerstroke Diesel Forum
Old 08-05-2010, 07:17 AM
I have a 2000 f250 and it will die sometimes while it its idiling in park or when to stop whole its in gear and it misses driving down the road. Need help really fast I gotta get it fixed ASAP
Old 08-05-2010, 07:37 AM
Carbon huffing animal
kinda hard to tell, have any more symptoms you can share?
Old 08-05-2010, 11:35 AM
Not really anymore I can think of. Just kinda misses and stuters while driving like in and out and now its started dieing while idiling and stuff I just gotta get it going cause its my pulling truck any help would be greatly helpful
Old 08-05-2010, 12:40 PM
did you put a fuel pressure gauge in with your zoodad mod? I guess you should start with the basics, air and fuel......, it's not getting one of the two, probably fuel.
Old 08-05-2010, 12:58 PM
I checked the pressure and it was fine operating normal. I talked to a guy and he said might be camshsft sensor
Old 08-05-2010, 01:09 PM
when my CPS went out, it took 20 - 30 minutes before it would crank again..... It never would crank right back up. Possible, but mine didn't go that way
Old 08-05-2010, 01:25 PM
Well I don't know what it is it won't throw a check engine light either
Old 08-05-2010, 02:26 PM
I don't think mine did either, but I can't remember for sure......
Old 08-06-2010, 12:34 PM
Power Stroker
Send a message via Skype™ to stroking 7.3
99-03 had a camshft sensor recall, check with dealer. They can run your VIN# and if it has not been replaced it's free. May not be your problem, just putting it out there. I had heard that oil pressure could effect idle also.
