turbo ?
i have an 01 7.3 i just put the a gt38r turbo on and i noticed im still getting alot of blow off and surge!!! my question is do i need to run a blow off valve if so who sells them, and do u guys think i can run my old banks big hoss wastegate or is it the same as the wastegate that comes on the gt38r?
thanks for the help; |
any help anyone
i have also recently bought a 38r and i'm having trouble. it only turns 23lbs of boost and sounds like its blowing a lot of air the truck runs really good empty but it feels like its under power with a heavy load. i have a big head wastegate and i've unhooked the hose to the gate trying to build more boost. a cant get an ideas from anyone on here. what kind of boost wil yours turn
Mines makin 30 lbs with the hose hooked up and the stock gt38r wastegate
The gate diaphram and rod you'll find on the 38R is the same one found on the stock turbo.
Disconnecting the red hose only disables the wastegate solenoid that assists in opening the gate to control boost. Drive pressure can still force the gate open. I'd check for boost / pre-turbo exhaust leaks if I was you. |
Fill out your guys signature with all your mods so people can help you diagnose your problems easier.
