DP tunes - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-18-2010, 06:12 PM Thread Starter
JSchuricht's Avatar
DP tunes
I recently installed a DP F6 with stock, 40 tow, 120 race, 140 aggressive and 1400 high idle. The tuner is working great, but I think I may have been a little too aggressive in my programing selections. I was hitting 1300 at 60-65mph on flat ground if I went WOT from a stop. I just installed a TE modded HPOP and am hitting the same temps by the time I hit 50mph.
So basically everything is working a little too well for my stock turbo and I am looking for suggestions on what tune to order so I don't have to back out so quick. Unfortunately a turbo upgrade is out of the question for the moment.
JSchuricht is offline
post #2 of 7 Old 07-18-2010, 06:40 PM
Flapdisk's Avatar
What condition was your turbo in before the f6? Depending on mileage, you might be needing a new turbo anyway..IMO. Maybe your tune is expecting more boost to match all of that fuel...
Flapdisk is offline
post #3 of 7 Old 07-18-2010, 06:44 PM
How does it run without the tune on? What numbers are you getting with the tuner off?
carolinaboy02powerstroke is offline
post #4 of 7 Old 07-18-2010, 07:02 PM Thread Starter
JSchuricht's Avatar
The turbo has 183k. I am not opposed to a better turbo, but I am currently registered in California so it would have to appear 100% stock.
Not sure what EGTs were stock, the F6 was a upgrade to a predator with a 100hp tune. With that tune, I could occasionally hit a peak of 30psi and only worry about EGTs if I was passing on a mountain.
post #5 of 7 Old 07-19-2010, 07:21 AM
Stroken7.3's Avatar
Call Jody, he will help you figure it out. DP tuner has excellent customer service.
2001 F-250, 6 speed trans, BDP Tunes, Autometer Ultralite gauges
Stroken7.3 is offline
post #6 of 7 Old 07-19-2010, 07:38 AM
Quoted: 3 Post(s)
just resign for a couple more years and get the reenlistment bonus to buy the new turbo... lol
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #7 of 7 Old 07-19-2010, 08:02 AM Thread Starter
JSchuricht's Avatar
He sure dose, already helped me out with a slight PCM code issue. Just looking for a broad array of suggestions.
