Zerex antifreeze
Anybody use Zerex antifreeze? I wich color of bottle do you use? I can get it prety cheap so I was gona go with it. I might be able to get a discount on CAT antifreeze too through work is all the CAT antifreeze ELC?
get the cat antifreeze!
Yea, coolant is something you Do Not want to cheap out on with a diesel. To do it right, a flush and refill with the "good stuff" is going to cost you @ $100
I know, it seems like a lot to spend for what we always thought of as "antifreeze" but, this really is a different situation. Because of the Very High compression ratio of our diesels, and the knock produced in the cylinder, there are cavitation bubbles that can form on the outside wall in the coolant. This cavitation can ultimately lead to a pit forming in the metal that could actually turn into a hole! Don't screw around, do it right, it's costs are initially high but over the long-run the ELC coolant lasts 100K or more so, you do get your money's worth ![]() Get Fleetright, Rotella, CAT, any of the good ELC's and you won't regret it (stay AWAY from Fords though, it sucks....) |
i have a 2002 with the yellow coolant i have to run |
It turns out, that Fords Yellow Stuff doesn't even meet the Minimum protection IH recommends for the engine. I think, in an effort to reduce inventory in the shops, Ford hoped to simply use one coolant for everything.
I don't know they could do that,,,, but they did and I guess got away with it! Maybe that says something about what's really necessary in the coolant because, obviously, it hasn't turned-out to be a problem.... But, when it's time for a coolant change, let's go with the "good stuff"
Go with the ELC... Add a coolant filter and forget about it... with nothing ever to add... I add 2 bottles of RMI-25 to keep things spotless inside.
if thats the case on the next flush im going to ELC (after i do more research of course) |
there is a tsb from international addressing which years can switch to elc coolant. if i remember correctly its all '99 and up, before that you have to stick to the green goo.
I suspect it's not that Ford Yellow is made to specially be compatible, but rather that they don't recommend using the Ethylene Glycol (Green silica based) because of some reaction. I wouldn't be concerned about changing to another ELC. Quote:
I think you can put ELC in ANY engine BUT,,,,, if it's got "Green" in there now you have to be sure to flush EVERY BIT of it out! A Super Flush out of the heater core is especially important because any silica left will gel in reaction to the new chemistry of the ELC. |
this is interesting info
i like what im hearing so far |
