Originally Posted by Zytek_Fan
Would the DIY boost fooler be worth doing on my early 99? I've yet to get an overboost SES light, but I thought I might do it before I do get the light.
Thoughts?
Do it before you get tunes. Otherwise you will probably defuel when you hit about 22 PSI.
Originally Posted by cvdenson
Do you have tunes? If so won't hurt. I'm running the ITP Overboost Annihilator and boosting to 26 psi wide open throttle. If I didn't have the boost fooler, I'd be throwing the 1211.
That wouldn't be the 1211. I forget the code for over boost but the 1211 is Injection Control Pressure Higher/Lower than Desired.
I will have tunes soon.
Definitely do it.
Originally Posted by CloverLeafFarm
on my E99 i went to napa and got some small black hose, and a T fitting, i spliced my vaccum line and connected it with the black hose and cut the hose to put the T in the middle to make my own.....with all my boots tight and no leaks i can find, i've seen as high as 45 psi on my Quadzilla Monitor so maybe it wasn't the best mod to do, but its still throwing the code so who knows
Thats because you didn't put in a boost fooler. A boost fooler tricks the PCM into thinking its only getting <22psi.
And how in the hell are you getting 45 PSI? Either the monitor is WAY off or you are running big injectors.
Or you might be seeing Absolute, which is approximately 14.7 psi higher than actual boost pressure.
