I Need Advice! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-06-2010, 11:19 PM Thread Starter
Im_Your_Hucklberry's Avatar
I Need Advice!
Alright i need some advice, the mods on my truck are in my sig. I am thinking about purchasing bigger injectors from beans im just not sure if i want to go with stage 1 REMAN or stage 2's. The only problem is i think i already have a week fuel pump either that or my fuel pressure gauge is messed up. After i get injectors i plan on getting a Air Dog fuel pump then custom tunes from TW(live tune) or beans. My truck currently has 225k miles on it but i feel it still is runnin strong and dont have to worry about it blowin. So what do you guys think?????
Lookin forward to the feedback i really need it.
01 F-350 4x4
6in Aussie Cut Stacks
SCT Tuned by DSP
aFe Stage 2 Intake
High Tech Turbo "Big Bad Wolf"
Isspro Gauges
Foil Delete
7in Flip Out Touch Screen
15in Q-Power Sub
Loud a** Outside Speaker and Audio System
Red Emergency Lights
MAXIMUS Train Horn over 175Db
Im_Your_Hucklberry is offline
post #2 of 10 Old 07-07-2010, 12:26 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I would get the fuel pump first to ensure you can properly feed the bigger injectors. There are a lot of guys on here that have went bigger than what you are going to go with that have a lot more miles so I think your truck would be ok.
dhanna6powerstroke is offline
post #3 of 10 Old 07-07-2010, 02:50 AM
get a kit from BOB diesel O-rings GUY that will boost your fuel pressure to 67 PSI constant from the stock pump the most my pressure drops now under wide open throttle is 5 PSI ...he gave me the kit free to try and test with my last order and it worked out no putting screws in my fuel regulator housing his kit has a kick butt anodized housing and three springs depending upon what final pressure you want ...I have an 01 7.3 ....anything above 60 PSI from a stock pump is great at WOT...
Replacement O-rings for Ford Diesel Engines
there is th link kit is 46.95 I'd rather do this than afro engineer something plus it looks cool!
I have some wasted injectors as well and am going to change over to singles shots asap just waiting on Jim Rosewood to call back so I can get the process started I'm not liking the 1600.00 price or the 1200.00 price others are charging ...supposedly he can blow that away we will see...!
scott52575 is offline
post #4 of 10 Old 07-07-2010, 11:12 AM Thread Starter
So its ok for me to be droping from 65 psi to 55 psi at WOT??? So should i go with the stage 1 or 2s and should i run beans tunes or get a live tune from TW. And please let me know what Jim as to say.
01 F-350 4x4
SCT Tuned by DSP
aFe Stage 2 Intake
Isspro Gauges
Foil Delete
15in Q-Power Sub
post #5 of 10 Old 07-07-2010, 06:49 PM Thread Starter
bump i need some advice im runnin outta time
01 F-350 4x4
SCT Tuned by DSP
aFe Stage 2 Intake
Isspro Gauges
Foil Delete
15in Q-Power Sub
post #6 of 10 Old 07-07-2010, 06:52 PM
Raul@Stealth Automotive's Avatar
ok first off you will need custom tunes for larger injectors.. if not its going to run like crap so it needs to be done at the same time... second i would go with stage 2 hybrid injectors and have Tony tune them down.. that way later on if you want to go bigger you can without having to buy new injectors...
3rd get the Adrenalin pump from Bob at dieselsite....
-Raul
Raul@Stealth Automotive is offline
post #7 of 10 Old 07-07-2010, 06:59 PM Thread Starter
Do i have to have the adrenaline
01 F-350 4x4
SCT Tuned by DSP
aFe Stage 2 Intake
Isspro Gauges
Foil Delete
15in Q-Power Sub
post #8 of 10 Old 07-07-2010, 09:09 PM Thread Starter
bump..............
01 F-350 4x4
SCT Tuned by DSP
aFe Stage 2 Intake
Isspro Gauges
Foil Delete
15in Q-Power Sub
post #9 of 10 Old 07-07-2010, 09:26 PM
i'm runnin' stage 2 single shots... they work the hpop less and seem to be doing fine. i am currently piecing together a regulated return system using two stock pumps... based on marty's diy fuel system in the mod section. having good clean fuel pressure under throttle is super important for your injectors... either a return system or an airdog... but you gotta get the air out of the fuel rails if you want your injectors to run right. So... my two cents= do your injectors and fuel system together... stage 2's are good for 400 hp... more for you with good tuning and your turbo.
filmsmith is offline
post #10 of 10 Old 07-07-2010, 10:34 PM Thread Starter
is this a good deal
160cc with 2k miles with 100% or 200% nozzles installed fro 2k and i keep my stockers
01 F-350 4x4
SCT Tuned by DSP
aFe Stage 2 Intake
Isspro Gauges
Foil Delete
15in Q-Power Sub
