Torque Converter swap? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-29-2010, 03:40 PM Thread Starter
Quoted: 2 Post(s)
At what point should the torque converter be considered to replace. Or modified, maybe a lock up switch. I don't know. A gujy said he shredded his and it destroyed the tranny and I would like to not so that
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-DieselSite Transmission Filter
--W/ Guage and Flush valve
-Factory Tech Valve Body
-Stage 2 Snow Performance Water Meth
-AFE Blade Runner Intake Manifold
-TurboMaster WasteGate Control
-DieselSite Boost Relief Valve
-AIH Delete
-Garrett High Flow Outlet
-Garrett NON-EBPV Pedestal
-Plenum Inserts
-Torque Converter Lock Up Switch
cesspool is offline
post #2 of 5 Old 06-29-2010, 09:23 PM
molokai's Avatar
your stock so you should be ok
molokai is offline
post #3 of 5 Old 06-30-2010, 03:08 AM Thread Starter
Quoted: 2 Post(s)
right now, but at what point does this become the weak link
-DIY Tymar Intake
-ZooDad
-4" MBRP w/ 5" tip
-Guages
-HPX
-CCV mod
-New boots...
-Fuel Rail X
-AIH Delete
-Plenum Inserts
cesspool is offline
post #4 of 5 Old 06-30-2010, 03:42 AM
Ole White
bigwhite7.3stroker's Avatar
unless your tranny is weak now you will be fine until you start upgrading injectors and a larger turbo
just a TW or DP Tuner, intake and exhaust you got nothing to worry about
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #5 of 5 Old 06-30-2010, 07:44 AM
molokai's Avatar
puf it this way,i still have the stock trans and converter except the VB. I know i will need a trans but its holding for now.
molokai is offline
