New TW Chip - Ford Powerstroke Diesel Forum
post #1 of 31 Old 06-28-2010, 09:57 AM Thread Starter
New TW Chip
Installed a 6 position TW chip last week on my buddy's truck we got from Raul at Stealth-Automotive. He got Economy, Daily, Street, Smoke, Heavy Tow, & Extreme. Truck was bought stock a year ago & the diesel bug bit him thanks to hanging out with me lol. It's a 2002 F-250 extended cab short box, purchased with 100,000miles. Had it lifted 6" & on 35's. Mod's are dual 6" mitre cut stacks, S&B intake, autometers & recently the TW chip with a pressure relief valve. The tunes definitely make some power & put the stacks to use, but the trans is shifting so hard & slips pretty bad. Feels like it has a HUGE stall converter in it. The trans wasn't having any issues before the chip what so ever. Economy & daily seem to shift great, firm & quick. But street, smoke, & extreme slip off the line & in-between gears when driving normal. When it does shift it slams into the next gear, but seems shift decent when I mash the go pedal. Does anybody else have these trans problems with the TW tunes? Also seeing a DTC at high RPM's in the street/extreme tunes, I'm guessing for low high pressure oil due to a weak HPOP, it'll go off after a couple of minutes or when I turn the truck off.
Sorry for the long post, any pointers would be great I haven't spent a lot of time working on the 7.3L
gomerpyle is offline
post #2 of 31 Old 06-28-2010, 10:41 AM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
If you're trans is stock, running high HP tunes is why it's slamming into gear.
Back to the blue oval: 08 F350 FX4 CCLB - DPF/EGR delete - Spartan tuner - S&B CAI - 4 in DP to 5 in SP
First truck: Early 99 F350 SC LB ZF6 4WD - SOLD
Zytek_Fan is offline
post #3 of 31 Old 06-28-2010, 10:51 AM Thread Starter
Would a JW or BTS valve body cure this problem with a re-burn on the chip? Or if you could point me to a thread your aware of I'd also appreciate it so I'm not beating an old topic to death, I've searched a few hours before posting & didn't find the right info.
post #4 of 31 Old 06-28-2010, 11:03 AM
I am having the same problem with the slamming of gears and need some answers as well. No one knows what it is...
carolinaboy02powerstroke is offline
post #5 of 31 Old 06-28-2010, 11:22 AM Thread Starter
I just got off the phone with Brian @ BTS. He said that a valve body should fix the problem. Give him a call, 1-870-422-3673. I'm just not sure if the chip will need re-burned or not after a valve body. Brian said it all depends on what tunes are currently loaded into the chip, so hopefully I'll hear something back from Tony or Raul today about it. I'm going to need a re-burn anyway after the adrenaline gets installed.
post #6 of 31 Old 06-28-2010, 11:34 AM
Finally, someone with some answers lol...Ill do some more searching
post #7 of 31 Old 06-28-2010, 11:36 AM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
Valve body and shift kit should solve the problem, but if you run in smoke or extreme a lot, you should get an upgraded torque converter as well.
post #8 of 31 Old 01-08-2011, 12:56 PM
Quoted: 3 Post(s)
I know this post is from forever ago, but im having the same problem with my tunes as well, just from 2nd to 3rd shifting, it revs out and slams like the drivetrain is gonna break off the truck. Doesnt do it in tow tunes though, any ideas?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #9 of 31 Old 01-08-2011, 01:04 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
I had some issues. Just get back with tony if you can and go from there.
But a vb will fix a lot of things? hmmmmm
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #10 of 31 Old 01-08-2011, 01:12 PM
storkerlovr's Avatar
a bts VB will trow you back in the seat if the rest of the trans is fine. but you may need a tc. a 6.0 tc would work great.
95 reg cab 4X4 STROKER
< trade for 5 speed???
new E40D
Autometer gauges
Gearhead tunes
EBP actuator deleted but not gutted
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
screw all this I just want a 6.4!!!!!!!!!!!!!!
wish list;
5 speed swap
stage 2 injectors
D66
"there may be snow on the mountain but that doesnt mean theirs no fire downstairs
storkerlovr is offline
