Suggestions for building my 7.3
Here we go... I am building a "new" engine for my truck. Theres nothing wrong with the old one I just figure I will start working on another one and when it gets done I will swap'em and build the first one. Here's what I am going for... Mileage...I would like to try for a legitimate 21+ MPG. I am at 18MPG now so it shouldn't be all that difficult. The factory 235hp 500tq, plus whatever all the crap I have done, is plenty of power for what I do with it so power is not my main concern although I will gladly take any extra I can come up with. I am also going to throw some "beef it up" parts in there also just for fun. I would like to hear everyones opinion and parts lists but lets try to be original here guys. In searching this forum I have found 7 posts where a person new to the diesel world is asking what to do for more power other than the obvious, intake, exhaust, blah blah blah, and 7 times people have said 238cc hybrids, big oil and a GT38R with a 1.00A/R. There is not a doubt in my mind that is a great power combo but thats not what everyone needs. I want everyones opinion as stated earlier but please also give reasons as to why you are suggesting a particular part. Anyone can make a list of parts, I want to know the why behind the list
My List: Single shot injectors (Swamps probably) not sure of the sizing yet - research shows better efficiency out of single shots Adrenaline HPOP - plenty of oil to work injectors Turbo. Not sure yet - move a bit more air if/when needed Regulated return - keep fuel in head where it belongs Twin factory pick-up pumps and bigger fuel line - plenty of fuel if/when needed. Plus I like the "fail safe" of having 2 pumps Custom tunes on 6 pos. chip - because they are needed to run single shots. Plus I can have a highway, tow and actafool setting. ![]() Balanced rotating assembly - cut down torsional vibration = smoother running = lees power lost to vibration Polished heads and exh. manifolds - smoother air flow Head studs - stronger than bolts Aftermarket head gaskets - so there are no worries about blowing one when goofing around Block girdle - stiffen block, cut down on block twist I think thats it. lol. Its probably not but I will add to it if I forgot anything. Sorry for the long post but just wanted to make sure all the info was out there. |
i have stage 3 injectors, regulated fuel return system, 6 pos. chip and i still run the stock hpop. If you get their hybrid injectors you shouldnt need another pump. My truck has 200,000 miles on it and it still runs great so far lol. The single shot injectors are a must and so is the regulated fuel return system so you dont starve the number 1 and 8 injectors, i would go with a FASS fuel system. Im not sure about the turbo cause im still looking for one myself, but it sounds like your heading in the right direction and not trying to cut corners.
-for fuel... i would run a regulated return with dual stock pumps. fass/airdog is a waste of money for us.
-for air... the turbo should be a gtp38r because its ball bearing and will be more efficient than the stock, i would also run a DIY or some type of aftermarket intake, followed by the Zoodad mod to allow more air flow. thats my .02 |
Oh well... I am not totally sold on the idea of Ball Bearing turbos yet. I know they work and hold up but I just haven't seen any proof that they are any better or worse than a regular bushing type turbo. Correct me if I'm wrong (it does happen from time to time lol). A ball bearing turbo is supposed to be more efficient because ball bearings have less friction a compared to a bushing type bearing... Correct? When the engine is running, the turbo is getting full pressure oil. The shaft is riding on a cushion of oil, not against the bushing itself. Just like the rod, main and cam bearings in the engine. ='s little to no friction. If someone has tested the difference between a bushing type and a BB turbo I would love to hear about it and see results.
Wow man, that seems like an awful lot of trouble to go through for 3mpg you want.
There really isn't a way to build a 7.3 for mileage ![]() Don't get me wrong, it's a nice list you've started, but it's not goin got give you what you're looking for IMO. It will give you some power, but mileage ?? ![]() Oh, and you sure won't need the girdle with that setup |
It would seem like alot of trouble but its really not. I was already planning on building another engine so why not throw some goodies in it. I also figured I should have a goal to shoot for, and since I don't really "need" any more power, mileage became my goal. Yeah, I know I don't won't need the girdle but one day I do plan, plan being the key word, on trying for 1,000hp on fuel alone (maybe not with this engine, deffinately not on this setup) so might as well get it now. Plus I like the idea of block girdles. Thanks for the post SouthPaw, if you have any suggestions I would love to here 'em. |
1,000 on fuel eh?
Thats a while down the road. Just thinking I might try my hand at it
