IDM Modification problem
Went to perform the IDM mod today and experienced a problem with the factory resistor pulling loose the small square "pad" to which it was soldered. I used a 23 watt soldering iron and solder wick to remove the resistor in hopes of avoiding overheating the board. I can't seem to get solder to stick to the small tabs on the board and the original pad refuses to reattach. Anyone experience this problem? Any helpful advice is appreciated.
Dumb question but are you good at soldering?? I can solder wire but I would never solder on a board this important without testing on some junk board.
What you need to do is find another place to attach to. Your going to need a good meeter with some sharp fine tipped probes. Hopefully you can see the traces and follow them to a point you can attach, but basically, you need to figure out where the traces lead from the old resistor solder pad and attach your new resistor somewhere in that circuit.
I am decent at soldering since we do it at work from time to time. Just suprised that the attachement plate came off the board so quickly/easily. Looking at soldering to the trace but it goes under an IC chip quickly after leaving the resistor.
whats this mod supposed to do again? refresh me.
The mod should provide better idle and quicker throttle response or this is my understanding. I have been able to solder the resistor to the incoming trace but don't have a diagram/print to show where they terminate. Anyone have a diagram or know how the resistor is positioned in the circuit? The traces go under the chip beside it. REALLY need to know where the trace terminate so I can verify no cold solder joint exists. Thanks.
