Sinister Diesels Map Fooler
Just got it in today
Took 10 minutes to install, ran her pretty hard down the interstate, no codes ![]() But before, i could hit abou 27psi, now its down to abou 22psi is this adjustable or am i really making 27 while my boost gauge is reading 22? This lil booger was well worth 40 bucks, if i can get my boost back to where it was lol
![]() Here it is, took longer to put the stupid clamps on the hose than it dad anything else! |
Anyone answer my boost question?
where is your boost gauge hooked up at?
its on the line that leads to the MAP sensor
I think i fixed it, tweaked a little
Do different gears run different PSI's? i had it in 6th(overdrive) and ran it up to about 90+ish(dont tell anyone ha) and i was back to my 26-27psi |
thats your problem. you need to hook the boost gauge up to the line between the intake pipe and the sinister regulator. Because the regulator wont let more than 22 psi through it and thats why the truck doesnt defuel. So your reading a regulated psi and not the actual pressure.
thats pretty weird. 90 psi would blow the head gasket and throw your headstuds through the hood! haha and what kinda gauge do you have that reads that high!?
i thought i had it in the right place?
its about 4 inches down the line i indicated by the RED arrow
and that line goes to the intake right?
