Mario's Motor - Ford Powerstroke Diesel Forum
Old 06-14-2010, 05:07 PM
International Threat
Mario's Motor
It all started with a bad running motor. Once the valve covers were off this is what I found. Lifter was F'd... and it was driven about 500 miles with no valves operating. The #1 piston is presumably fried so instead of spending a lot of money on machine work, to just swap in forged rods with a new motor.
So the truck is here, I went and got a forged rod motor for it.
The valve train had all been removed so I had to pull the heads since some had dropped into the cylinders.
Prepping the block for paint after I get the studs/gaskets.
Old 06-14-2010, 06:17 PM
piston damage caused by valve float?
or
lifter get stuck in the bore and cause the piston to valve contact and then bend the pushrod?
Old 06-14-2010, 06:20 PM
sorry for getting off track marty but its required to take the cab off to pull the engine right?
Old 06-14-2010, 06:28 PM
no need to pull motor
Old 06-14-2010, 07:02 PM
Looks like you used a few rolls of "E" tape. lol
Old 06-14-2010, 07:08 PM
Raging Lunatic
Still, more posts without secrets...............damn! Like those purple gloves, what's next???? PINK!
Looking good, Marty.
Old 06-15-2010, 04:14 AM
or
2 Broken pushrods on cylinder #1, the valves were not opening for 500 miles...
Nope, just take everything off the front and take her out.
1, and didn't have any masking tape and surely wasn't stopping to go get some LOL.
LOL, hey they were given to me by a guy whose truck I worked on so free is good .
Old 06-15-2010, 05:56 AM
But what caused the broken pushrods, they dont usually just break, especially not both, and if they broke then the valves would stay fully seated and there shouldn't be any piston contact right?
Old 06-15-2010, 05:45 PM
I am not sure, probably something to the tune of WOT on ice from the story I've been told.
Anyway, yes when the pushrods broke the valves stayed closed.
Here are the heads I finished today...
Old 06-16-2010, 12:29 PM
where is a good place to buy a used motor for a f250? of where is a good place to buy a rebuild kit along with forged rods? mine has little puffs of smoke coming out of the motor but when i turn the cap over ontop of the oil filler it doesn't blow off the cap nor does any smoke puff out
