TS CHIP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! - Ford Powerstroke Diesel Forum
Old 06-04-2010, 06:22 PM
Ok here we go, got a TS Chip today. Got it in, 50 & 75 was not that big of difference. Put it on 100 and it done better but shifted hard going into high. Put it on 140 and I thought the tranny had came out from under the truck. It was like it shifted into high twice. Has anyone had this problem? I have 4 in exhaust, aftermarket air filter. Had the 1705 SuperChip in it before and never had this problem. I know they are going to be a difference but should it shift that hard? The reason for the change was fuel mileage and a little more gitty-up. Does the PHP TW or DP shift this hard.
Thanks GUYS
Old 06-04-2010, 06:38 PM
my php shifts real sweet in the 80 hp dd the 120 race it shifts pretty hard into 3rd when the converter locks but not like the trans is gona come out i would be real good if the converter would lock up sooner witch I am going to get the switch to do that and then it will be real good
Old 06-30-2010, 04:21 PM
Dose your truck smoke? I just put a ts chip on mine and it makes almost no black smoke at all.
Old 06-30-2010, 06:05 PM
My 80 php smokes alittle but 120 can black out a intersection
Old 06-30-2010, 06:21 PM
nope not much my smoke setting will not smoke called php they said my hpop is weak so you might have the same problem ??
Old 06-30-2010, 06:32 PM
haha my PHP will cloud out intersections..on 80 i can make it barrel out...and i hit 30psi max boost
Old 06-30-2010, 06:36 PM
It cant be that i had a diablo and a sct chip and they both smoked like hell. Now no smoke with the ts.
Old 06-30-2010, 06:37 PM
careful I have heard that anything over 25-26 will burn your stock turbo up but thats bad ***
