dual oil pumps
been searching for a thread on this what is a good second oil pump for my 2002
a second stocker is all I have ever heard of. But save yourself some time and money and just get a stealth stage 1 pump. Much better than any twin pump. Twin pumps rob an extra 30-40hp because you have to turn 2 pumps.
Best HPOP is a single Stealth...reduced Oil shearing more oil and none of the stock pumps problems..
I got rid of my leaky dual pumps for the single stealth.
This is so far from the truth
Wow. Pumps more, but less shearing?
Explain that one? How much more flow? Does anyone know?
it flows more than some twin pumps I had. Well they flowed a lot all over my engine.
Back on topic here the stealth pump pumps a higher volume but about the same PSI as a single stocker therefore putting the same stress on the oil. it is simple physics of fluid dynamics. And I believe he was saying the stealth pump is less shearing than a twin pump setup. Two pump that equals 14 axial pistons. that is twice as many as stock, well duh. Running 2 pumps is bad for numerous reasons. The reason our trucks chug and have that distinctive tone is because of dead spots in the oil pressure where the axial pistons are at top and bottom dead center. Now when you put 2 pumps together there is no way to time them and make them work good together. One setup might run smooth where as the other might run like dog poo. Also when you run 2 pumps they heat up the oil twice as fast. And to further defeat the purpose of cool oil some dual pump makers like to run the IPR bleed off back into the HPOP reservoir. that sucks hot oil right back into the pumps. Not to mention the lost power of the second pump. The stealth is the smoothest pump money can buy hands down. but most people dont need or want that amount of oil. The adrenaline will work just fine, and it has a lot of good components inside of it that allow it to run smoother and turn easier. And the swash plate is at a different angle other than 15-17. All I know is it is between 17 and 21 degrees. This is not personal opinion it is fact this is serious hands on research through multiple vendors. I tried dual pumps on my truck went through 5 sets in 1000 miles. Never again. I read tons of documents from ford service manuals and navistar manuals as well. I also tore a pump apart to know exactly what axial pistons are and how they work. Rant over I just dont want someone to be without a truck for 3 months like I was. Why spend 1800 on dual pumps when the stealth stage one is better and 1500. phew long one there. |
Thats what happened to me too when I put a Stealth on my truck, was without my truck for 4 months because I had to change out a motor. |
wish I could afford a stealth they look so cool. I never got to install one even. I would do it for free just to play with it. But I should buy a turbo first 38r here I come
