Colors don't match on ISSPRO - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-31-2010, 07:22 PM Thread Starter
RoldOvr05's Avatar
Just finished installing guages - well partway! Diesel Manor didn't include the boost T-fitting so I will call them tommorow. Question is that the Boost guage doesn't light up like the others. I have the Enhanced Visibility white face with green glow. Installed per the instructions with backlights going to the dimmer switch. All three guages dimm properly just the boost guage is more white. Pyro and Trans are just a backlite green and the boost you can see a white ring. More white and less green. Was going to call ISSPRO tommorow just wondering if any suggestions or similiar experiences.
1999 Ford F-250 Ext. Cab, 6" lift, ProComp Xterrain Radial 35 x 12.5 (keep switching between ProComp and Toyo All-Terrain 37 x 13.5), MBRP Cool Duals, AFE Stage 2 intake - Isspro 3 guage, 6.0 tranny cooler
RoldOvr05 is offline
post #2 of 10 Old 05-31-2010, 07:24 PM Thread Starter
RoldOvr05's Avatar
Oh yeah, Boost is a 0 to 40 PSI - Like it matters!
post #3 of 10 Old 06-01-2010, 04:40 AM
SJB
SJB's Avatar
Quoted: 2 Post(s)
It is my understanding that the Isspro's use a green cover that goes over the bulbs. Maybe they forgot to include this cover for the one gauge, but included it for the other two?
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- DIY Intake w/ AMSOIL 4095 washable/reusable filter
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
post #4 of 10 Old 06-01-2010, 04:44 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
thats right. the isspro gauges i put in my OBS had a lil green (or red) rubber cover hat went over the bulb to changet he the backlight color. sounds liek one of ur bu;bs didnt get one on it or it fell off int he gauge housing.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #5 of 10 Old 06-01-2010, 05:03 AM
riddin' high
Dasaliac03's Avatar
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
my old gauges did that, they were the cheapest things out there
have a pic so we can see how bad?
SOLD - '03 7.3, MBRP, 38r, DP F5, HPX, RR, DIY 6637, 05 OEM Harley front, 08 OEM rear & mirrors, 20" Moto Metal, 35" Nitto's
Current - '11 6.7 FX4 Larait, Ready Lift 3.5" Leveling Kit, '13 Larait Wheels
Dasaliac03 is offline
post #6 of 10 Old 06-01-2010, 09:58 AM
MichaelP's Avatar
As mentioned above, it is likely the bulb cover (affectionately known in Engineering as "bulb condoms"). Please pull the bulb out and see if it is missing, and if it fell off inside the gauge. My guess is it is missing altogether. Please let me know if that is the case and we will get you a replacement.
Regards,
Michael Pliska
Engineering Manager
1995 F350 PSD CC DRW, 271k miles
10 ISSPRO Performax™ gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" DP, Tymar 5" exhaust, Cat's lost, Baby Swamps, Swamps tuning, Tricumulator springs and Accumulator Valve, Tru-Cool 4590
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET)
92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 T/A 455
GOA, IDPA & NRA member and certified firearms instructor
MichaelP is offline
post #7 of 10 Old 06-01-2010, 10:16 AM
Quoted: 4 Post(s)
. i was gonna call them that but i wanted to keep it at least pg13.
Brett
post #8 of 10 Old 06-01-2010, 10:27 AM
elm302's Avatar
Feedback Score: 3 reviews
If it helps I used a sharpy to fine tune the colors.
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #9 of 10 Old 06-01-2010, 04:17 PM
Cumminskiller2007's Avatar
I have the same problem but not worried about it but I can tell you that I removed the bulb covers from my pyro and boost gauge and one is still alot dimer than the other dont remeber which one been a bit since I drove it hopefully it will be road worthy this weekend
2001 F350 S/C 4x4 DRW 6spd
475K
DpTuner-high idle, 80E, 100Perf, 120Race, 4inch TB exhaust with 5in. Single black Stack, Custom 4in. intake with AEM dry filter, ISSPRO boost,pyro and water temp, zoodad mod, Beans 1.0 A/R non wastegate turbine housing
Cumminskiller2007 is offline
post #10 of 10 Old 06-01-2010, 05:37 PM
my boost guage was to bright so i just used a black marker and put a line on the bulb and stuck the rubber back on it and now there all the same.
burl09 is offline
