Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 04-06-2006, 04:08 PM
Dieseldad Dieseldad is offline
What next...
Couple questions about the next step. I HAVE K&N Intake, MBRP 4" T.B. Ex., Edge Evo and Boost/Pyro Guages.
What would be some smaller mods ($$$) for HP or engine performance???
What would help with throttle response ?? Seems to be alittle lag time when you get on it.
Is a propane injection worth the $$$$$$$$.....
Any comments or help would be appreciated. Thanks guys.
Old 04-06-2006, 04:34 PM
wesjones wesjones is offline
how bout a larger exhaust system?
wes
Old 04-06-2006, 09:17 PM
lilredpowerstroke lilredpowerstroke is offline
Ballin' on a budget
As long as you use it sparingly you should be fine. People add windows to their block when they get greedy with the 'pane. As for smaller mods I think I would have to get rid of the K&N intake and go with the AFE stage 2 air intake. I love mine, helped out with EGT's and gave me very decent power increase.
Old 04-07-2006, 10:49 AM
I do have the MBRP 4" Exhaust. The propane (for now anyway) is just a dream.
It seems that the AFE stage II is the intake to have. What about wastegate actuator and high pressure fuel pumps. Do they help at all with HP or performance ?? Diesel motors are still knida new to me. Thanks again.
Old 04-07-2006, 04:56 PM
Deeno Deeno is offline
7-UP man
You can unplug the vacuum line at the wastegate and plug it off with something, like a small screw. That will give you about 3 to 5 psi more boost. As far as high pressure fuel pumps are concerned, that's something I have never messed with. Some of the guys on here have though.
Old 04-07-2006, 10:06 PM
Ballin' on a budget
You could also shim the fuel regulator with will give some more cheap power. If you do the take the vaccum line off you might wanna get a boost relief valve so that the computer doesn't defuel from having too much boost.
Old 04-09-2006, 07:39 AM
Ramsmoker Ramsmoker is offline
Powerstroke Techie
Talking what next
Try shimming your fuel pressure regulator to 75psi or like mine, 90psi. Get a ICP controler from wildbill at defuser.com. Also Bill can get you a HPX line. These are inexpencive and seat of the pants mods.
Old 04-10-2006, 01:12 PM
DJM DJM is offline
Before you get too out of controll with the power you might want to look into beefing up the tranny. I found that out the hard way $3k later but it's beefed up now first thing I would do is upgrade the TC very week point in these trannys.
Old 04-10-2006, 01:16 PM
DJM DJM is offline
How do you guys go about shimming the regulator ? heard about it a couple of times but never seen or heard how it's done .
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
