Hey Guys,
I am in the process of repairing/rebuilding the front end on my 2002 F350 4x4 DRW and need help locating some parts. Do any of you guy know if someone makes a stainless brake line kit for a stock suspension truck? I have found the Skyjacker kit and a couple others but they seem to be for 4-8 inch lift trucks and I think there would be a lot of extra line to figure out how to secure correctly. Secondly, I need the front wheel adapter/spacer that mounts between the hub bearing assy and the wheel/tire. I had 7 of the 8 hub bearing studs shear off while driving and the wheel adapter has bad egged-out mount holes. Is this a dealer only part?
Many thanks for your guidance!
Rick
Pittsburgh, PA
Rick
Pittsburgh, PA
