I have a 2000 7.3 4x4 dually limited edition shot box I wannt to work my way up on the mods tell me the supports I need to run with my 08 6.4 with sct 310 package
Youll need
to be sure you have forged rods
girdle
push rods
Arp studs
Comp 910 spring
Mild port job on heads
full fuel system
238cc\80% or 238\100%
42r turbo
Adrenaline, Stealth, or modded 17*
transmission either DI or BTS
there is some other odds and ends but that is close to a 600 hp 7.3
On my dmax i do all the work because im more familier with it..Im new to the strokes so ill probly let a local diesel performance shop work on it..ill do the minor stuff but headstuds and things...they can get that. lol i maily just dont have the time to learn how to build it..are there any cheap mods that i can do? and anybody have an edge for sale?
has there ever been a 800hp DD 7.3?? if you REALLY have the money, fab up some twins, becaese lord knows they do not make a kit for these trucks yet i dont think. theres not to much space under there for 2 turbos
about 475 for a wildman chip from total diesel performance for a 6pos chip and all you need is the info for your truck if you look at the site you will see what i mean and see what you need
$500 should set you out with custom tunes from the above-mentioned vendors. Jody from DP-Tuner lives about 15mins from my office so I go to him. Other Tuners have very good reps here as well.
I'm not too familiar with EFIlive, my understanding is it is alot the same. Basically you tell your tuner about your truck, they send you a chip which would best suite your mods.
A step up from that is live tuning, the best you can get. Any tuner can do it, they do a ride along with you, or if they have a dyno, they use that.
I have hi-idle, tow, econ, street, extreme and smoke.
My truck RARELY leaves extreme. Unless I am crusing 40-45 mph, then I flip to street because extreme doesn't shift into od till 48ish.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
