hey guys, just picked up an e99 f250 yesterday and i noticed the back sits a good 3 to 4 inches higher then the front, any leveling kits out there for it??? also can i just make my own drop front hanger brakets, or would i have to extended the trac bar too ??
I have an early 99 2wd i just leveled with some 97 Rancho 3" lift springs, 2 1/2" coil spacers, and upper ball joint camber adjusters. It sits level now so i think the springs werent quite 3" of lift. My camber is still 2 degrees positive but that is with in spec and over the last 6k miles have not had any uneven wear. I searched up and down for the drop brackets but they are hard to come by. I suggest the springs spacers and new shocks. Maybe all new ball joints why your at it.
I put a skyjacker add a leaf on my early. Got it from Topgun and it came with the track bar bracket. I think i had bout 250 in it. Ride is stock. That should work unless your wanting to spend more $ and go with all new springs.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
